? for guys using Caltracs
Discussion in 'Competition Camaros' started by Bill81, May 5, 2010.
  1. 383Camaro79
    383Camaro79 Veteran Member
    806
    Feb 11, 2000
    Alton, IL, U.S.
    I made a set, Im a CNC machinist & made all the parts at work. I used good QA1 rod ends & all grade 8 bolts & nuts & spent about $100 total. I duno how anyone could make a set for $40 i had more than that in my rod ends.
  2. ATM
    ATM Veteran Member Lifetime Gold Member
    2,268
    Oct 10, 2009
    Morris, Illinois
    How much would you charge to make me a set? ;)
  3. buckracer24
    buckracer24 Veteran Member
    310
    Apr 14, 2006
    PEI CANADA
    Your getting heim joints and tube ends mixed up,tube ends are threaded inserts that go into the tube and get welded in place then you put your heim joints in.
  4. buckracer24
    310
    Apr 14, 2006
    PEI CANADA
    I didn't skimp with any of the parts, all the brackets were cut on a cnc laser cutter out of 3/16 mild steel(a friend of mine did that for me) the bars are 1.250od tube(had that), the tube ends I got at mcmaster carr for $8 each (left and right hand thread) heim joints I got from the same friend that cut the brackets, aluminum round stock for spacers and bushings I got at work and turned it on my lathe at home and all the nuts bolts and washers are grade 8 which I also got from work.
    thats how I built mine so cheap and even if I had to spend $100 or $150 I would still be way ahead right?
  5. Bill81
    Bill81 Veteran Member
    2,084
    Mar 3, 2000
    Denton, TX
    I said rod ends not tube ends. And rod ends and heim joints are the same thing. Look it up on jegs. Also, where are you coming up with the 430 cost. I just got mine in yesterday and they were 362.
  6. buckracer24
    310
    Apr 14, 2006
    PEI CANADA
    sorry,I consider tube ends the things that get welded to the tube and the heim joints thread into them.
    $362US $430 Canadian EH!!!! lol
  7. onelapduster
    onelapduster Veteran Member
    720
    May 5, 2010
    South Joursey
    Anyone got those measurements? I am interested in making my own. Post it up or PM me the info, thanks!
    http://www.mcmaster.com/#
    I know it was said before, but here is the link to mcmaster-carr. You can find just about anything you want.
  8. sunkenloot
    sunkenloot Veteran Member Gold Member
    221
    Aug 30, 2010
    Dallas, TX
    Did anyone ever get some measurements or templates on these? Looked around and havent found any. In paticular, Im looking for the tube length. Speedway has some Heim joints on closeout and would like to order the Swedged tubing while Im at it.
  9. gregh
    gregh Moderator Staff Member Lifetime Gold Member
    4,173
    Jun 24, 2003
    Calgary, Alberta, Canada
    Camertom on here made his own set(& we\ve compared his to my bought set) & the one problem no one, including us, has solved is adjusting them quickly & easily.
    Caltracs have one regular & one reverse thread heim joint per bar. To adjust them you undo the lock nut & spin the tube. With Tom's homemade bars, using regular thread ends, you have remove the through bolt & adjust the length, then jack up the car to reinstall the bar.
    I can adjust mine in 2 minutes with one wrench while Tom's can take 1/2 hour or more.
    I've looked & never been able to find a set of reverse thread heim joints &/or the tap to thread the other end of the adjusting bar.
  10. ATM
    2,268
    Oct 10, 2009
    Morris, Illinois
    You can get reverse thread heim joints.
