Ford 9" Conversion from drum to disks w/stock replacements
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by JohnL71RS, Mar 1, 2013.
  1. JohnL71RS
    JohnL71RS Veteran Member
    1,684
    62
    Apr 12, 2010
    Marrero, LA
    I am trying to find out some information about rear disks on a ford 9". I have a 9" and i want to convert to disk brakes. I heard that it is possible to scavenge parts off of old cars. I heard old Lincolns, granadas, and possible the broncos/explorers. Did anyone do this or know how and what parts and cars to get it from. I know there is kits out there from aftermarket companies, but it really isn't in my budget to do that. Any information would be appreciated.
  2. 73 L92
    73 L92 Veteran Member
    126
    Apr 4, 2012
    Carlos, MN
    Try KORE3. He can offer a kit that runs C5 rear discs with parking brakes.
    Or the older 97 -2002 Camaro calipers have the e-brake built in. Then all you need to add is the brackets. Kind of like a Baer kit on the cheap. I've done a couple of 10 bolts that way and a 9". Worked well.
  3. Skip Fix
    Skip Fix Veteran Member
    2,217
    25
    Mar 21, 2007
    Katy,Texas
    All depends if they are still Ford ends or aftermarket with a GM pattern.
    Lots of the Ford guys use Explorer rear disc setups.
