Formula for engine RPM for rear axle ratio.
Discussion in 'Transmission & Driveline Topics' started by john Gialanella, Nov 5, 2020.
  1. 77 cruiser
    77 cruiser Veteran Member
    587
    36
    Nov 17, 2006
    Frostbite Falls MN
    3.55
  2. jeff swisher
    jeff swisher Veteran Member
    1,835
    624
    Apr 26, 2018
    Yukon Oklahoma
    Jodi on post 3 was darn near correct with the math and an automatic without a lock up converter.
    336 which is a given to make things work.
    The math for a standard transmission with ZERO clutch slippage is.
    336 X gear ratio X MPH, divided by Tire diameter = RPM
    So you have .
    336 x 3.31 x 80 divided by 26.3 = 3382 RPM
    Now add 10% for converter slippage you get 3720 RPM and you stated you see 3750 at 80 MPH.
    I say about right.
    You could have more or less slippage depending on Drag Coefficient weight and how tight or loose the converter is.
    I have one low stall 12" converter that has 2400 rpm stall but slips over 15% and another converter I have that is 9" and 4500 stall that has about 1% at 7000 rpm.
    The difference is crazy.
    77 cruiser likes this.
