Found Rubber Flaps by rear wheel well
Discussion in 'Body Restoration' started by czizza, Apr 11, 2015.
  1. czizza
    czizza Veteran Member
    1,079
    87
    Jan 8, 2004
    N. Massapequa, NY, USA
    I was working on the back of my car and I found these two flaps ... I then started pulling shtuff (not misspelled) out of it when I was done this is how much came out of the drivers side.
    Put the foot in there (size 11) to give you perspective.
  2. Orange71
    Orange71 Veteran Member Lifetime Gold Member
    3,792
    Jan 31, 2001
    Finksburg, MD
    Yep, factory rocker clean-out cover.
  3. 2nd gen Guy
    2nd gen Guy Veteran Member
    612
    Jul 29, 2012
    Coon Rapids, Mn
    Yep, dirty lil secret
  4. Twisted_Metal
    27,678
    1,299
    You just made your car faster! :D
  5. clay's70
    clay's70 Moderator Staff Member Lifetime Gold Member
    2,129
    67
    May 3, 2008
    Chesterfield, VA (Richmond)
    Every little bit helps!!
  6. Zstar
    Zstar Veteran Member
    1,781
    448
    Mar 23, 2014
    Ocala, Florida
    You were lucky, I pulled out wads of fiber like insulation that was somehow stuffed in there.
  7. CamaroMan79
    CamaroMan79 Veteran Member Lifetime Gold Member
    5,204
    10
    Jun 10, 2001
    Selah, WA
    What year car is this off of? Looks different than my 78.
  8. berg2695
    berg2695 Veteran Member
    318
    71
    Nov 13, 2011
    AUBURN, WA
    Those rockers are designed to flow air and rainwater whenever the car is in motion. This keeps them dry and relatively clean. If the drain get plugged up, that's bad. I think it is a good idea to pull the rubber flaps off every few years and flush the rockers with a garden hose. Just remove the plastic grill from the top of the cowl, then shove the hose down the side plenum all the way down to the rocker area. Start slow until water comes out of the drains freely. Two cautions, however: Depending on how fast you run the hose, water may leak out of the door sill pinch weld and run into the interior. Have lots of towels to soak it up before it wets the carpet. Also, the best time to do it is on a hot day, right before a long drive. That way everything can dry out quickly! Sorry this post is so wordy, but I think this is an important and little known maintenance chore that will help our classics last longer. (And be faster, like Twisted said)
  9. czizza
    1,079
    87
    Jan 8, 2004
    1979
  10. czizza
    1,079
    87
    Jan 8, 2004
    Speeds important ... I will see if I can do that ... I did not know it was connected to the Cowl dump.
