Frame Connector Suggestions
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by 78formuler, Jun 16, 2021.
  1. 78formuler
    78formuler New Member
    Apr 24, 2020
    Ohio
    Whats everyone running for subframe connectors? I really like the design of the hotchkis but they are out of stock until August. Any input would be appreciated. Car is 78 formula with mild sbc 350.
  2. SPG
    SPG Bumblebee Builder
    1,124
    412
    Sep 1, 2018
    Sacramento
    real question is
    are you ok with welding? because you get much better connectors if you weld them.
    I will be using chassiworks subframe connectors due to me having a torque arm suspension
    A lot of people like the global west subframe connectors, and it's what I was personally going to buy if I stuck with leaf springs
  3. 73Z L92
    73Z L92 Veteran Member
    243
    94
    Jan 25, 2011
    Carlos, MN
    Custom Works a vendor on here has them.
  4. Zspoiler
    Zspoiler Veteran Member
    4,064
    465
    May 6, 2012
    Federal Way, Washington
    I use Chassis Engineering on my 1979 Z-258
  5. dave@ztech
    [email protected] Veteran Member Lifetime Gold Member
    4,652
    1,072
    Mar 27, 2016
    NY
    I used Pro Touring F body , great fit, great price
  6. 1970_Z28_503
    1970_Z28_503 Veteran Member
    131
    17
    Apr 12, 2017
    Oregon
    Global West and Custom works are both good from what I hear, and I think PTFB makes a good set.
  7. badazz81z28
    20,970
    1,472
    Alabama
    If you can weld, the DSE are the best ones out there. I’m a fan of Global West and Alston.
    Tim Ward likes this.
  8. JUNKYARD AUTOCROSSER
    JUNKYARD AUTOCROSSER Member
    89
    27
    Nov 16, 2009
    Los Angeles, CA
    I tried the subframe connectors from Heitz . They were a bolt on and not welded. I did skid pad and slalom testing and did not notice any performance improvements. I did not like the looks as they hung below the car from the forward leaf spring perch to the existing subframe. They also scraped on some driveways and some speedbumps. Upon closer inspection, the attachment points of the Heitz subframe connector absorb all of the torsion stress at each end of the subframe connector which is separated by the full length of the subframe connector. Not good! I like the theory behind the Detroit Speed subframe connector because it is welded along the full length of the connector to the body distributing a uniform load along the full length of the subframe connector. Much stronger. Also it is less noticeable because it is mounted higher into the body. The downside of the Detroit Speed subframe connector is you have to cut up the body to install it. I autox with the Heitz subframe connector for about two years, and then removed it. Each connector weighed 10 lbs for a total of 20 lbs.
  9. Tim Ward
    Tim Ward New Member
    Jun 17, 2021
    DSE for me, I've had them for 15+ years and it one of the best things I've done to the car. Yes you do have to cut the floor pan and I had my reservations but sure glad I went ahead and did it. I Highly recommend them. Now the fact that it's a convertible I think weld in is the only option to eliminate as much flex as possible. You can jack one corner and lift the entire side with VERY little flex. Since these were installed many vendors have released connectors but I still think they rank very high on the list.
  10. Coadster32
    2,302
    367
    Oct 2, 2013
    Milford,CT
    I went with tube type Alstom. Welded in.
