Front end question (tie rod, torque spec....)
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by CamaroRS80, Aug 19, 2010.
Thread Status:
Not open for further replies.
  1. CamaroRS80
    CamaroRS80 Veteran Member
    757
    Aug 14, 1999
    Montreal,Qc,Canada
    Hi,
    I finished rebuilding my front end tonight.
    1-While I was bolting the drive side inner tie rod end, I was torquing it to 35-40lbs and it stripped the ball stud.... is it ok to put the cotter pin and leave it like that or I need to replace the tie-rod right away.
    2-What is the torque spec on the Idler arm bolt to center link and the bolt from the steering box to the center link?
    Thank you
  2. BondoSpecial
    8,694
    Sep 20, 2004
    Southern Maryland
    was this an import-brand tie rod? noo not okay to leave like that
  3. CamaroRS80
    757
    Aug 14, 1999
    Montreal,Qc,Canada
    dont want to be mean so I wont tell where it is from, but im kinda disapointed... I bought a full front end rebuild kit.
    I'll get a Moog replacement then.. it sucks, I paid 400$ for the kit, and around 100$ to replace defective/lower quality parts....
  4. BondoSpecial
    8,694
    Sep 20, 2004
    Southern Maryland
    I pieced together all my front end rebuilds so i knew exactly where each piece came from and what country of origin and quality level it was...sucks to hear you had so many problems
  5. CamaroRS80
    757
    Aug 14, 1999
    Montreal,Qc,Canada
    anyone know the torque spec for the idler arm bolt and steering box bolt to centerlink??
  6. vidguy
    vidguy New Member
    16
    Aug 10, 2010
    ca
    I stripped a Ball Joint that was in the Front End Kit I bought from Someone as well. And the tie rod connectors were not threaded in far enough... I too ended up buying Moog Parts and replacing the Ball Joints. I got the tie rod connectors replaced so that was good.
    The Ball Joint was not the same as the MOOG Ball Joint I bought.
    In my 75 Firebird Manual, the Idler Torque was 35.
    Seems to me (I'm not home near the manual at the moment) that the center link bolts were all 35.
  7. CamaroRS80
    757
    Aug 14, 1999
    Montreal,Qc,Canada
    thank you very much, so 35ft-lbs it is !
    Welcome to the board!
  8. tedm_SS
    tedm_SS BANNED
    90
    Jan 9, 2011
    Missouri
    This just happend to us today. Was helping putting the steering together and the nut would not torque to find out the threads let go.
    Whats the verdict? I wouldnt want to ride in his car now, Im sure he wouldnt want to drive it.
  9. frankz
    frankz Veteran Member
    2,119
    26
    Aug 24, 2009
    Illinois
    Sorry to hear this but it does make me glad I only use Moog and Howe parts. That could get down right scary!
  10. tedm_SS
    tedm_SS BANNED
    90
    Jan 9, 2011
    Missouri
    My bud is trying to get a hold of the seller. Maybe there is bad batch.
Thread Status:
