Front rotors seem out of round
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by dcozzi, Jun 27, 2021.
  1. dcozzi
    dcozzi Veteran Member
    4,232
    1,202
    May 1, 2002
    Phoenix, AZ
    They are new from Wilwood but they rub like they are bent on the brake pad when you spin the tire. Everything on the front spindle is new except the bearing races. The spindle was in good shape when I put it together.
    So, now that I am going to take it all apart again, is there anything I should look for? I bought a dial indicator and another set of rotors from Summit because I have seen stories of them being off from the manufacturer before. I will check the rotor and hub then, if they both wobble, I guess it is the race or seat.
    Any similar experiences and suggestions are appreciated.
  2. xten
    xten Veteran Member
    4,376
    3,405
    Sep 24, 2014
    Pittsburgh, Pa.
    I don't know if this is exactly what you're running into Dave, but years ago I put a set of cheapo rotors on my S-10. First time through the traps at ~ 120 MPH I thought it was going to rattle the thing apart. Went to the local AP store and told the old guy and he suggested a different (better) set of rotors, BUT he said get them checked for run-out. Even brand new, they need trued up. He took me in the back to the brake lathe and I couldn't believe how much run-out there was, and they were brand new out of the box. Maybe get the rotors checked?
    Dave Nelson and Zstar like this.
  3. dcozzi
    4,232
    1,202
    May 1, 2002
    Phoenix, AZ
    I thought about that too but the idea of truing brand new rotors would not register properly in my head.o_O
    I will do this if the dial indicator shows the hub as true.
    It would be great if this is all I have to do.
    Crappy thing is I have to take it apart again.
  4. Fbird
    5,788
    1,679
    Feb 12, 2011
    atlanta, ga
    The indicator will tale the tale!! numbers don't lie!!! Said every Toolmaker I have ever worked with!
    dcozzi likes this.
  5. djorgensen3
    djorgensen3 Veteran Member
    800
    168
    Oct 15, 2009
    Peoria, Az
    My buddy owns a Big O Tire out in Fountain Hills. This happens all the time there. So much so that they now just do a cleanup cut on all new rotors they install to avoid returns due to vibration.
  6. COPO
    21,085
    2,611
    My Raybestos 5214R rotors out of the box were perfect on my 70.
  7. dcozzi
    4,232
    1,202
    May 1, 2002
    Phoenix, AZ
    I wish Wilwood had the same QC in their manufacturing process. For the price, I would pay another $20+ to have it true out of the box.
  8. Knuckle Dragger
    16,511
    2,839
    Nov 2, 2002
    Waddell AZ
    He needs to buy a better grade of rotors. When I was working the tire shops we had to do the same, now I'm working where quality is king they work just fine out of the box.
    dale68z likes this.
  9. dcozzi
    4,232
    1,202
    May 1, 2002
    Phoenix, AZ
    Well, I was not far off. The hubs were dead nuts straight but the rotors were not. Thanks Wilwood. It looks like there are spots where they took out metal to balance them but, why not have them true as well? Who knows.
    I bought a dial caliper. The face has 50 marks. Twice around registers the center dial as .1".
    The rotor was moving the dial 7 spaces. Does this mean it is .007" off?
    Maybe the pad is just touching and making enough contact to make noise. It does slow the wheel a bit though when you spin it.
  10. cadillac_al
    cadillac_al Veteran Member
    1,022
    151
    Apr 22, 2015
    Maine
    I would be disappointed but I'll bet they will be fine once they are turned/resurfaced. I used to run into this fairly often in the 1980's and turned quite a few new rotors back then. I haven't had to do it all in the last 20 years. It's been so long I can't even remember the correct terminology. I think around here we used to say we want our rotors turned; sounds weird now.
