Front Spring Recommendations
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by vlmohr, Jul 22, 2015.
  1. vlmohr
    vlmohr Veteran Member
    179
    Jul 8, 2010
    Bellevue, IA
    Would like to drop my 79 about an inch. I am currently sitting at 14 3/8 inches from frnder lip to wheel center. I am seeing a lot of people go with the moog 5610. I would like a firm but not feel like I'm in a 3/4 ton ford pick up LOL.
  2. dman79z28
    dman79z28 Member
    34
    Sep 11, 2011
    Chaffee Missouri
    I would skip the springs and go with the QA1 pro coilover setup. It will handle better, have a tighter feel and best part is you can adjust your ride height to what you want. I dropped my 79z28 about 2 inches and it looked good!!! $459.00 at Jegs.
  3. brooksman9
    brooksman9 Veteran Member
    6,138
    213
    Jun 10, 2007
    Olive Branch, MS
    I used the 5610's on my 77 I had. No regrets and I think it dropped maybe an inch. Rode good too.
  4. Mountaineer
    Mountaineer Veteran Member
    2,092
    8
    Mar 6, 1999
    Where Mountaineers are free
    Got a part #? Thanks!
  5. badazz81z28
    17,808
    708
    Alabama
    If the Op goes coil over, look for a more true coil over set up.( Keith custom works). Requires some welding, but it's as right as it can be without a aftermarket frame.
  6. camarolife78
    camarolife78 Veteran Member
    549
    Jul 22, 2014
    Gardner, KS
    Goto the QA1 website, and put in your car, it will guide you through what is best for you! I went to the P/N section and it gave the exact part number per spring rate and I used that P/N in summit or jegs to see the price and availability
    https://www.qa1.net/
  7. vlmohr
    179
    Jul 8, 2010
    Bellevue, IA
    Would like to stay with the conventional spring as I just bought new shocks to install and found one spring was broken. And the coil over is a little on the pricey side for me. Thanks for the info on the coil overs though.
  8. JWZ28
    JWZ28 Veteran Member
    1,239
    Feb 27, 2011
    Alabama
    I went with the Eibach lowering springs. They're stiffer than stock but not too bad.
  9. Bumpad_Z28
    Bumpad_Z28 Veteran Member
    500
    Apr 9, 2004
    Logan, UT
    Custom Works 2g springs :)
  10. Fbird
    4,455
    830
    Feb 12, 2011
    atlanta, ga
    5610's
    refering to MOOG suspension parts #5610
