Front Spring Recommendations
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by vlmohr, Jul 22, 2015.
  1. vlmohr
    vlmohr Veteran Member
    179
    Jul 8, 2010
    Bellevue, IA
    yes
  2. Lowend
    15,313
    626
    Mar 25, 1999
    San Jose, CA, USA
    I dislike QA1 for many reasons from the design of the whole system to how the shocks are built internally
    If you must do a built-in coilover. The Vari-Shocks are a much better setup
  3. bygblok
    bygblok Veteran Member
    769
    Nov 28, 2010
    Pensacola Florida
    I'm going to the PTFB lower arms and the Viking double-adjustable coil overs on my 70. Everyone recommended the 450lb springs too for everyday and mildly aggressive street driving.
  4. Skip Fix
    Skip Fix Veteran Member
    2,209
    24
    Mar 21, 2007
    Katy,Texas
    Got an older but new QA coilover I'll make a deal on!
  5. vlmohr
    179
    Jul 8, 2010
    Bellevue, IA
    Thanks for the replies. I really can't afford the coil-overs.
    So I decided to put the Moog 5610 springs in. Found that both my springs were broken. After i got it back together it sat almost where it was 14 3/8". Took it out for a drive and felt a noticeable improvement. It settled at about 14". Hoping that with a few more miles it will settle a little more. But overall happy with the stance and looks it has right now.
  6. Francesco
    Francesco Veteran Member
    120
    Jan 9, 2015
    Drummondville, Quebec
    Hi! My question is more about the rear shocks. Right now I have 20" shocks in the rear but I was recommended to get the 24" shocks. I have a Monroe shock number but I wanted to know if it was compatible with my 79. The number is 5820 in the Monroe line. Is it compatible?
    Thanks
  7. biker
    biker Veteran Member
    1,359
    295
    Dec 7, 2014
    New Liskeard Ontario Canada
    So, do the 5610's sit similar to stock? Mine are totally baffed (5608) and I would like a stance as close to stock as possible.
  8. SMCZ28
    SMCZ28 Veteran Member
    818
    Jun 15, 2010
    United States
    I wouldn't say that the 5610s sit similar to stock since I read mostly about them being a go to budget drop spring.
  9. biker
    1,359
    295
    Dec 7, 2014
    Agreed, but I also read many people posting about how much of a crap shoot it is to get a ride height that is actually advertised for a given spring. I'd be OK with an inch lower, but 2 and beyond is a bit much for me.
  10. vlmohr
    179
    Jul 8, 2010
    Bellevue, IA
