Fuel pressure?
Discussion in 'Engine Topic' started by smallblockchev, Jun 18, 2015.
  1. smallblockchev
    smallblockchev Veteran Member
    365
    Dec 23, 2011
    st michael, mn
    What I mean for stock is factory motor, carb, etc..
  2. Coadster32
    2,171
    307
    Oct 2, 2013
    Milford,CT
    I had the same issue on my Eddy 1406. I bought the eddy mechanical fuel pump, which self regulates at about 5.5psi. (I though it was cleaner than re-routing with an in-line regulator.) Also put on a carb spacer. I think mine got a little heat soaked. Hope this helps out your issue as well.
  3. Twisted_Metal
    29,071
    2,127
    Overloaded... You mean flooded?
    Electric choke?
    My Q-jet will sometimes flood a little bit if you start it up after it sits for 30-45 minutes. (The choke cools down enough to close but the engine doesn't need the choke.)
    Less than 30 mins or more than an hour and it starts perfectly.
  4. rchydzik
    897
    39
    Nov 13, 1999
    Colbert, WA USA
    I have had problems with the stock fuel pump putting out too much pressure. I used a Holley regulator and set it to 5psi. No problems since.
  5. sschevellefan
    sschevellefan Veteran Member
    529
    Nov 2, 2007
    Sacramento, CA
    Edelbrock are very sensitive to fuel psi.
  6. DFWJ
    DFWJ Veteran Member
    300
    Aug 16, 2012
    DFW
    a properly tuned EFI setup would solve the issue
  7. sschevellefan
    529
    Nov 2, 2007
    Sacramento, CA
    Yeah at about 5X the cost too. A properly tuned carb works just fine.
  8. DFWJ
    DFWJ Veteran Member
    300
    Aug 16, 2012
    DFW
    Agreed, probably need more than 5 times to do it right.
  9. rocket dawg
    rocket dawg Veteran Member
    415
    47
    May 5, 2015
    Grand Rapids Mi
    I had fuel pressure issues at one time. And the gas would drain back into the tank after it was warm and then sat for a a bit. I have a 400 ( 406 ) truck engine in my car. I used the truck fuel pump. WRONG. I switched to an AC Delco fuel pump for a camaro and it solved everything. Not all fuel pumps are created equal. I was chasing my tail for months on this issue. A tech for Summit racing suggested I do this before anything else, he said, "not an aftermarket fuel pump, a factory AC Delco pump" He was right. Haven't had an issue since.
