fuel pumps
Discussion in 'High Tech Retrofits' started by Dallas camaro, Jul 1, 2015.
  1. Dallas camaro
    Dallas camaro Member
    30
    Apr 6, 2015
    Midlothian,tx
    i know alot of folks on here are using the vette works and tanks inc set up for their ls swaps. has anyone out there used the msd external fuel pump with their ls swap? if so how is it?
  2. cvhu
    cvhu Member
    97
    Jan 18, 2012
    sarnia, ontario, canada
    i am using the msd pump with regulator from speed way motors, its seems to run and idle fine but i haven't driven the car yet as i am still building it, but my fuel pressure seems a little high between 63 and 65 psi, the regulator is suppose to keep it at 58 psi so i am not sure
  3. DFWJ
    DFWJ Veteran Member
    300
    Aug 16, 2012
    DFW
    Is the regulator adjustable?
    I wouldn't worry about a difference from 58 to 65 psi, the ls ecu will be fine within that range and the engine should run
