Gas tank removal - with transverse muffler
Discussion in 'Engine Topic' started by 73RATTYZ28, Apr 29, 2020.
  1. 73RATTYZ28
    73RATTYZ28 Veteran Member
    562
    44
    Feb 23, 2001
    White Plains NY USA
    Is there enough room to remove the tank with the transfers muffler still in place?
    thanks
  2. bodymanbill
    bodymanbill Veteran Member
    1,706
    1,373
    Feb 1, 2007
    South Park Pa
    Yes just removed mine this winter without removing anything else and without scratching anything on my 73.
  3. roeville
    roeville Veteran Member
    1,276
    116
    Oct 9, 2000
    SF East Bay CA
    I too have removed mine without touching anything else.
  4. Twisted_Metal
    29,670
    2,517
    Raise the rear and put jack stands under the ends of the rear axle housing. (Chock the front wheels.)
    Support the tank with a floor jack. (Hopefully the tank is empty or close to empty.)
    The two straps are unbolted at the rear and unhooked from hangers in the front.
    Disconnect, or cut, the rubber fuel lines. (You probably want to replace the rubber lines anyway.)
    Lower the tank enough to disconnect the ground and sending unit wires.
    (You can disconnect the black ground wire from the frame instead of the sending unit.)
    Slide it forward a bit so the filler neck clears the tail panel and pull it out.
    Good Luck!
  5. 73RATTYZ28
    562
    44
    Feb 23, 2001
    White Plains NY USA
    Anyone have the issue of the fill tube being too high to get the gas cap on??? Bend it? Feel like it may break
  6. Twisted_Metal
    29,670
    2,517
    I’ve heard other members have had that problem.
    Bending it does work.
    The tank will flex a bit around the neck before the solder breaks loose.
  7. 73RATTYZ28
    562
    44
    Feb 23, 2001
    White Plains NY USA
    Thanks bending it worked too bad the stock gas cap doesn’t fit, anyone have a recommendation?
