Gaspods: Legit or the next Turbonator ??
Discussion in 'The BS Topic' started by ColdBastrd, Sep 2, 2014.
  1. fbody_mike
    fbody_mike Veteran Member
    1,009
    20
    Mar 24, 2009
    San Gabriel Valley, California
    Kinda like the Subaru or Evo vortex generators that are put on the roofs. Just google Subaru vortex generator or diffuser and you will see it.
    I vote turbonator too. Because just randomly placing these on a roof is gonna be less hit and more miss with the benefits.
  2. rwild1967
    rwild1967 Veteran Member
    251
    Aug 11, 2009
    Look behind you!
    I can see where, properly placed, they could make a MINIMAL (less than 1% at a guess) difference in fuel economy by disrupting the airflow over the car.
    That said proper placement will be difficult without your own wind tunnel.
  3. ULTM8Z
    ULTM8Z Veteran Member
    10,123
    913
    May 19, 2000
    Los Angeles
    http://www.discovery.com/tv-shows/mythbusters/videos/dimpled-car-minimyth.htm You have to scroll down to get to the dimpled car video.
    Anything you can do to break up the boundary layer friction between your car's surface and the air stream will help reduce drag. But look what they had to do to get a non-trivial result.
    I believe some sea animals use this principle for hydrodynamics as well...
    That said, I'm skeptical these pods will reduce anything except your checking account...
  4. Lowend
    16,465
    1,262
    Mar 25, 1999
    San Jose, CA, USA
    They are vortex generators and do have a small effect at very high speeds. The Mistubishi Evo has them on the roof from the factory.
    Like any aerodynamic aspect, they have to be placed very specifically to have any positive effect. Just arbitrarily sticking fins on the car will do more harm than good
  5. MotionClone
    MotionClone Veteran Member
    1,479
    303
    Jan 20, 2014
    away from the crazies
    From their website:
    :screwup:
  6. Twisted_Metal
    29,962
    2,715
    Have you ever wondered why a golf ball flies so far.....?
    Introducing...
    The Aero-Dimpler! :cool:
    Put the hammer down on restrictive airflow which is costing you precious fossil fuels!!!
    You can achieve a 20% savings in fuel cost by using the specially designed Aero-Dimpler to create the perfectly aerodynamic golf ball dimple pattern in your car's sheet metal.
    Are we serious? You bet!!!!
    It's more effective at fuel conservation than those expensive, gimmicky gaspods and you only need one, cheap reusable tool (along with our special template) to accomplish the job on ALL of your steel or aluminum bodied vehicles! :D
    Kit comes complete with the Aero-Dimpler
    Instructions and a reusable template to achieve perfect results whether you're 8 or 80!
    :D Order yours today!!!! :D
    NOTE: Not for use on fiberglass, carbon fiber or plastics automotive panels.
    Weird thing is... The Aero-Dimpler just might work.
    I think I'll apply for a patent just in case testing proves successful. :crazy:
  7. Todd80Z28
    11,857
    424
    Jun 11, 2002
    Northern VA
    Why's that :screwup:? Is it wrong information?
    1. I suspect these things do work to improve airflow.
    2. I suspect that user claims in their test section are grossly over actual effects (6%??)
    3. I'd like to know how you go about placing these on a gazillion different models. Do they have instructions for each vehicle model??
    I think there might be a lot of placebo effects going on in the numbers shown- folks purposely driving more gently, more slowly, etc... I'd be happy to test them to the best of my ability for free, and happy to pay for them if I see even 3% improvement. Of course, that offer doesn't appear to be available...
  8. millpondmonster
    millpondmonster Veteran Member
    297
    Mar 6, 2012
    far enough out it takes 3 days to get a text messa
    This principle with larger dimples DOES work.......(they tested it on mythbusters):crazy:
  9. flowjoe
    8,047
    45
    Feb 7, 2006
    SoCal
    A tip of the hat to you sir! Comic Genius!
    I'd patent it any way - make an infomercial and you'd be on your way.
  10. Lowend
    16,465
    1,262
    Mar 25, 1999
    San Jose, CA, USA
