• The Forum will be unavailable on March 27, 2023 from 8:AM to 12:00 PM EST for maintenance.
Gauge Bezel Removal Question
camaro73lt
981
Hanover, PA
Has anyone dropped / lowered their steering column to make removal of the plastic gauge bezel easier? I have removed my bezel a few times without dropping the steering column and it is very tight and tedious. I use painter's tape over the column to avoid scratches, but each time I worry about snapping the bezel. I was thinking if the column could be lowered a bit to make removal of the bezel easier.
suds788
122
Fort Morgan, CO
That's how I normally do it. Makes life alot easier!
camaro73lt
981
Hanover, PA
Green hornet - thanks info. Is is fairly obvious how to drop the column? If you can explain in a few steps, I'd appreciate it. I noticed a mount / plate on the column directly under the dash... haven't gone any farther. Thanks!
Hrothgar
61
Easy, 2 bolts that are located around the middle of the column. Just loosen them up a bit and you will have the extra room
Yep. I had no luck removing the bezel without dropping the column. You'll also have to remove part of the underside of the dash panel where the heater/ac controls and ashtray is to drop the column. Couple of screws in total, plus the 2 bolts for the column. So much easier then trying to manuever a bezel in/out without damaging it.
FS87LT
220
DFW, TX
ALSO, do not forget the fishing wire wire for the instrument panel shift position indicator, unless you have a manual trans. That little "wire" attaches to the shift bowl on the column, with one hex-head screw. Easy to do. Column will not come down all the way with it attached!
