gauge Bezel - TAB REPAIR INFO and PICS
Discussion in 'Interior Restoration' started by 77RS, Feb 10, 2010.
  1. 77RS
    77RS Veteran Member Lifetime Gold Member
    2,940
    Oct 18, 2006
    Asheboro, NC
    This is a tech article on repairing the broken mounting tabs on the 70-81 Camaro gauge bezel. I've tried several methods of repairing tabs, and this seems to be the best so far. With a little patience and just a few bucks, you can repair tabs at home.
    This is a typical gauge housing with all four mounting tabs broken. Only two of the tabs are shown here.
    Cut the vertical tab completely flush with the horizontal portion of the tab. This will give a sturdy mounting point for the new plastic to be put into place.
    IMPORTANT - The gauge housing is made of ABS plastic. The new tabs should also be made of ABS plastic material. ABS bonds very well with super glues. I sometimes use plastic cut from spare guage housings. In this example, an ABS 4" pipe plug was used. Although products such as LEXAN (polycarbonate resin) are much stronger than ABS, it will not bond very well with ABS.
    Cut a piece of ABS into small squares slightly larger than needed. Remove all the dust and leave a clean edge.
    Make sure the mating surfaces of the gauge housing and the replacement tab are clean. Use a quality super glue (I use LockTite Super Max) and spread liberally on both mounting surface. Apply the new tab flush with the gauge housing horizontal tab mounting area.
    I use an aluminum duct tape to overlap the repair area. this will add a little strength and also give a clean smooth surface for the repair guides.
    Repeat the procedure on all tabs to be repaired.
    I have duplicated the exact size and shape of the factory tabs in a stick-on decal. I will post info on how to get these decals at the end of the article.
    Apply the decal flush with the bottom of the horizontal mounting surface. the decal is outlined in black to show where to cut and drill.
  2. 77RS
    2,940
    Oct 18, 2006
    Asheboro, NC
    I use a bandsaw to rough cut the tabs, then use a dremel to round out the edges. Use a 3/16" drill bit to drill the mounting hole.
    After cutting, there will be reinforcement tape left on both sides of the tab.
    When finished, you will have a strong mounting tab that should last for years to come. Here is a pic of one of the tabs that was just repaired with a 3 lb hammer hanging from it.
  3. 77RS
    2,940
    Oct 18, 2006
    Asheboro, NC
    If anyone is interested in getting the repair guide decals, please send me a PM or an email.
    For a limited time, I will provide these for only $2 per set for members here at NastyZ28. I only ask that you provide me with a self addressed stamped envelope, and I ask that you only get them if you're seriously going to use them.
    This is my small way of giving back to the community.
    Thanks!
    Daniel
    Foxfarmer likes this.
  4. BTTB71SS
    BTTB71SS Veteran Member Lifetime Gold Member
    4,797
    May 10, 2006
    Harris, MN
    Daniel,
    Great write up... Thanks for doing this ....;)
    Sent ya PM :)
  5. spoonLT1355
    spoonLT1355 Veteran Member Lifetime Gold Member
    5,511
    Mar 1, 2003
    Rockledge Pa
    As usual, ANOTHER great fix from Daniel !!!
    You are filling in some of the greatly needed items for our cars !!
  6. l16pilot
    1,933
    171
    Dec 13, 2004
    Hurlock, MD, USA
    Excellent...very well written and thought out.
  7. laninme
    laninme Member
    35
    Nov 16, 2008
    Great information and instruction
  8. 174Z28
    174Z28 New Member
    11
    Aug 24, 2008
    Independence Missouri
    PM Sent :bowtie:
  9. 77RS
    2,940
    Oct 18, 2006
    Asheboro, NC
    Thanks for the compliments. :) This has worked well for me.
    The broken tabs is the one mutual problem for all of our cars. Hopefully this will help a lot of people out.
  10. 5spd540
    12,399
    16
    Sep 19, 2009
    Guyton, GA
    Well it is strong
