gauge Bezel - TAB REPAIR INFO and PICS
Discussion in 'Interior Restoration' started by 77RS, Feb 10, 2010.
  1. 71camaro71
    71camaro71 New Member
    26
    Nov 10, 2011
    arlington, Texas
    Oh yeah, I also added some metal reinforcements for all that plastic to hold onto. But it did blend with the greenish plastic the guage housing is made of. And it was quite an experiment too. If I had to do it again I think I'd try the superglue and some ABS pieces. Much easier to work with and less fumes and fire and burn possibilities.
  2. bowtie98607
    bowtie98607 Veteran Member Lifetime Gold Member
    285
    Dec 7, 2000
    Vancouver, Washington
    PM sent.
  3. ZGrooveShip
    ZGrooveShip New Member
    23
    Aug 1, 2012
    United States
    I printed out your image and will try and use it to shape some tabs out of Mighty Putty, as I don't have the dremel & bandsaw. If that doesn't work, I'll go the ABS plastic & superglue route somehow.
    I really appreciate you posting the image. I PM'ed you for your address so I can send you a couple of bucks for using your work.
    Thanks again
  4. ebd12694
    ebd12694 Veteran Member
    208
    Jul 27, 2011
    Dallas, TX
    This is so easy a 17 year old can do it. Im 17... lol
    but seriously i appreciate this informative post it has saved me some money in my costly resto.
  5. reinhardt79
    reinhardt79 Veteran Member
    858
    May 12, 2002
    VA BCH, VA
    I know this thread is 5 years old, BUT is it still possible to get the decals? I just pulled my cluster out yesterday to find all but one tab broken.
  6. Sunny Z/28
    Sunny Z/28 Member Gold Member
    76
    33
    Jun 7, 2020
    Great post, I've printed the image and will try my luck with the process. Thanks much.
  7. Cmunzen
    Cmunzen New Member
    15
    Jun 1, 2020
    This is how I fixed mine...
    First, I collected and glued all the fragments I had available from the original supports and filled the missing spaces with casting wax. (Photos 1, 2, 3 and 4)
    20D2617A-F213-4326-BA9F-1FE13B64A55E.jpeg CD939084-9871-4146-A087-A988DE121B05.jpeg F74DF2EF-B74E-4D31-9882-EC65E0FF64D6.jpeg 8480236C-2ECB-4F29-8B26-7DF9E7A1EA6F.jpeg
    Then I made some negatives on the original supports with silicone (photos 5 and 6)
    7354564C-EE9B-4557-9F95-B9688F260968.jpeg 1E14EAE3-A434-407C-8AC1-6076D2EA1BD0.jpeg
    Then I removed the original fragments´┐╝´┐╝ and fill the molds with acrylic resin. (Photos 7, 8)
    7D5B3278-4EF8-4137-BF2D-96E67E10B1F4.jpeg 4F858CD2-1115-40D9-A0F8-1D173E729F95.jpeg
    A little polished and ready ... stronger than the original.
    Cheers
    [email protected] likes this.
  8. dickeymoore
    dickeymoore Member
    96
    8
    May 7, 2010
    Atlanta,Ga.
    I know this is a old post but any way to repar the mounting tabs inside the dash were the gauge cluster bolts to?Thanks
  9. brooksman9
    brooksman9 Veteran Member
    6,280
    299
    Jun 10, 2007
    Olive Branch, MS
    Seems like I was able to glue some washers or something where some of that was missing on the last car I did but that was several years ago. If I get a chance I'll look back through my build threads and see if there is anything in there.
