Gauge cluster connector
Discussion in 'Electrical Systems' started by 80's AL, Feb 2, 2019.
  1. 80's AL
    80's AL Member
    72
    21
    Sep 23, 2017
    Dallas, GA
  2. Green hornet
    Green hornet Veteran Member
    1,996
    466
    Oct 11, 2015
    North Bay, CA
    There is a small tab inside the connector body that needs to be released. You need to insert a paper clip or small pick in from the wire side of the connector body. You should see a very small channel for access. Once you remove it make sure to bend the tab up so that it will lock back in. Hope this helps
  3. 80's AL
    80's AL Member
    72
    21
    Sep 23, 2017
    Dallas, GA
    It does...thanks Green Hornet
