Gauge cluster mounting brackets?
May 2, 2020
42
Installing gauge cluster looks like something is missing does anyone have a picture of where the guage cluster mounts to brackets and what nots I really promise myself self no more cars someone else took apart put broke it on this one
31,660
The gauge cluster has tabs which are held to the dash with hex-head cap screws.
There are no other mounting brackets.
If your tabs are missing…
May 2, 2020
42
My gauge cluster is brand new Dakota digital where on the dash does it mount do you have pictures or does it mount to the dash pad
31,660
I believe the Dakota Digital cluster mounts in the same place as the factory one.
Open the link in post#2 and you can se where it mounts.
73 Z
1,264
Los Angeles, Ca
Yes, mounts to dash pad as does stock, then cover with bezel
May 2, 2020
42
Thank you I had not put up the new cluster to the dash but saw those 4 indentations on the dash pad which is the original and they didn't have any hole thru them already thanks again for the pictures
