Gear Vendors Question
Discussion in 'Camaro Questions' started by MACs-72-Z28, Oct 7, 2021.
  1. ULTM8Z
    ULTM8Z Veteran Member
    10,208
    947
    May 19, 2000
    Los Angeles
    Lift up the rear end of the car. Put the car in neutral. Be sure to observe all good safety protocols like jackets stands and wheel chocks.
    Turn one of the rear wheels around one revolution and count the number of times the driveshaft turns. Example... the drive shaft turns over about ~3.75 times... you likely have a 3.73 axle ratio. Or it turns over ~3.50 times you probably have a 3.42 or a 3.55.
    MACs-72-Z28 likes this.
  2. MACs-72-Z28
    MACs-72-Z28 Member
    35
    Apr 18, 2020
    I'll try to get a pic
  3. MACs-72-Z28
    MACs-72-Z28 Member
    35
    Apr 18, 2020
    Ok, I'll do that, thanks
  4. MACs-72-Z28
    MACs-72-Z28 Member
    35
    Apr 18, 2020
    So, I turned the wheels one complete rotation and the driveshaft only spun 1.5 times. Is that correct?
  5. MACs-72-Z28
    MACs-72-Z28 Member
    35
    Apr 18, 2020
    For those asking about the tranny and pics of where the floor is cut, here's the info and pics.
    Driver's side:
    Tremmec
    CUCA - 3351
    Tag:
    TUET 10860 B
    92246731
    CA223
    00257
  6. MACs-72-Z28
    MACs-72-Z28 Member
    35
    Apr 18, 2020
    20211016_145609.jpg 20211016_145554.jpg 20211016_145609.jpg 20211016_144117.jpg 20211016_142646.jpg 20211016_142613.jpg 20211016_142539.jpg 20211016_142529.jpg 20211016_142529.jpg 20211016_142506.jpg 20211016_142427.jpg 20211016_142413.jpg 20211016_142411.jpg 20211016_142328.jpg
  7. MACs-72-Z28
    MACs-72-Z28 Member
    35
    Apr 18, 2020
    20211016_142142.jpg 20211016_142115.jpg 20211016_142038.jpg 20211016_142015.jpg 20211016_141953.jpg 20211016_141942.jpg 20211016_140948.jpg 20211016_140923.jpg 20211016_140913.jpg
  8. MACs-72-Z28
    MACs-72-Z28 Member
    35
    Apr 18, 2020
    Ok, it looks like it's a TR6060 from maybe around 2011. Can't find exacts. Don't know if it's a Magnum or not.
  9. ULTM8Z
    10,208
    947
    May 19, 2000
    Los Angeles
    1.5? Did you have the transmission in neutral?
  10. sandlapper
    sandlapper Veteran Member
    920
    367
    Oct 9, 2020
    SE CSA
    Kinda reminds me of a mid-sixties dodge straight box truck; a band I knew used to haul their gear. 4 speed w/ a two-speed axle. Unreliable gas guzzling POS. When I painted its hood, I also shortened the chrome dodge lettering on hood to just "DOG" ... lucky for them it didn't also have TRUCK in same script. those were heady days.
