Gen IV LS Engine/4L80E swap into '73 Camaro
Discussion in 'High Tech Retrofits' started by jakeshoe, Aug 20, 2009.
  1. PolarBear
    1,189
    Apr 24, 2008
    NJ
    The LS3 did come after the L92, L92 came in the trucks but they carried the same design over to the car engine.
    I really dont want an iron block, if I can have aluminum I dont want it :eek: I am waiting until the 7th of september to see if I win something and if I do then I will get my aluminum eninge afterall [​IMG] If I dont win then I have a lead on an inexpensive stock LS1 but the guy will have to "think" about it. The LS1 would be most likely pending not buy this house I am going to look at tomorrow
  2. jakeshoe
    8,894
    31
    Dec 8, 2000
    Republic of Texas
    I also have the L92 crate engines ;)
    I have new 5.3 aluminum blocks for $450 each :bowtie:
  3. 1970camaroRS
    1970camaroRS Veteran Member
    2,606
    Mar 4, 2001
    Everett, WA
    What part number are those headers and how are they fitting so far? Would really like to know as I'm thinking about the Edelbrocks, but don't want to fork over $600 if they don't fit well.
  4. JAMMINJ007
    JAMMINJ007 Veteran Member
    397
    Dec 27, 2005
    Houston, Tx
    headers
    The part # is 65073. Summit has them for $519 which is a steal of deal considering they are already coated and are stainless steel. Check on ls1tech they are supposed to be a direct drop in with no fitment problems. Several guys have used them in swaps:)
  5. PolarBear
    1,189
    Apr 24, 2008
    NJ
    I didnt think they were coated stainless, interesting and good to know. I may consider them then, even though I have the ATS mounts......
  6. BonzoHansen
    19,870
    1,075
    Jun 1, 2005
    Scott from Hamilton, NJ
  7. jakeshoe
    8,894
    31
    Dec 8, 2000
    Republic of Texas
    I added a webpage to the site for the retrofits.
    It has some shots of the headers, oil pan fitment, etc.
    http://jakesperformance.com/Engine_Retrofits.html
    Today we pulled the engine back out, swapped cams and valvesprings, timing set and cover to delete VVT, the oil pickup and pan, and flexplate. Re-installed the engine, trans with converter, and headers. Trial fitted the radiator assembly. So far so good. We have to look at some steering arm to oil pan clearance issues.
    Tomorrow we'll be modifying the crossmember, the driveshaft is ordered, and I have a bunch of stuff to get on the way now, fittings and plumbing,
  8. Pump Guy
    Pump Guy New Member
    13
    Apr 2, 2009
    Edmonton, Alberta Canada
    Jake,
    What do you do for the trans cross member? Is it just a matter of cutting and moving the mount position to suit?
    I am in process of doing the same stop, but am waiting to get the trans done before I pull the old 350/350....
  9. rscamaro73
    rscamaro73 Administrator Staff Member
    14,972
    16
    May 30, 1999
    Striking fear and destroying the enemy
    Lookin good Jake.
  10. 71RS/SS396
    71RS/SS396 Veteran Member
    2,639
    41
    Aug 26, 2008
    Wake Forest NC
    Just curious as to why you would delete the VVT?
