Gen V 454 questions
Discussion in 'Engine Topic' started by RIP170, Sep 9, 2021.
  1. RIP170
    RIP170 New Member
    Sep 9, 2021
    Hello, I have a 78 camaro Lt, I have the opportunity to purchase a low mile 454 out of a 1990 454ss for cheap and i would switch this to a carb setup. I've been putting as much hours in of research as i can with limited info. I know i would need a electric fuel pump and a msd ignition. I really don't know any other roadblocks, does anyone have any opinions on going this route and if it's worth it?
  2. camarochevy1970
    camarochevy1970 Veteran Member
    8,048
    183
    Jan 23, 2003
    Pittsburgh, PA
    can make some decent power out of those with a few mods. In fact, I think Hot Rod took one to like 500 hp for not a lot of cash a few years ago.
    I know the Gen 6 didn't have a fuel pump boss, guessing same for Gen 5?
  3. RIP170
    RIP170 New Member
    Sep 9, 2021
    Yea Gen 5 didn't have them
  4. G72Zed
    G72Zed Veteran Member
    3,138
    1,594
    Sep 8, 2015
    I have a new GM Gen VI block I bought for a customer build, it has the mech. fuel pump provision, although he will be electric fuel pumps, nice to have the option regardless, simple and functional in under certain applications under 900hp.
  5. Rustbucket350
    Rustbucket350 Veteran Member
    1,067
    93
    Sep 4, 2013
    Oviedo, Florida
    Well you would want a holley blue electric pump and a carbed intake. An edelbrock rpm style is a good all around choice.
  6. carhead22000
    carhead22000 oldblue
    687
    302
    Sep 5, 2011
    canada
    easy to make big power from any big block.i love them.depending on what you want and how far you want to go. I found a gen 4 like that,just replaced rings, bearings, did a cam swap.put a set of trick flow 280 ovals on,airgap intake,800 edelbrock.car works sum nice.4 speed car.
  7. RIP170
    RIP170 New Member
    Sep 9, 2021
    Carhead i think ive seen some of your car pics, i belive you're running a stock 80's z28 hood just slightly modified right?
  8. carhead22000
    687
    302
    Sep 5, 2011
    canada
    yes ,abit of love under hood.the solenoid is gone for the flaps. And a bit of trimming. I wanted car to look stock.
  9. sandlapper
    sandlapper Veteran Member
    850
    318
    Oct 9, 2020
    SE CSA
    OP RIP170
    Why would you need (or want) an msd ignition? Your 78's OE Delco HEI dist should be more than adequate; and more reliable than any msd.
    If the 90 BBC has an OE roller cam, suggest retrofit 78's OE HEI with a new melonized dist gear ACDelco pn 10456413.
    That melonized gear's available at USA AutoZone about $45 USD.
    If it's truly 1990 OE 454SS truck; motor may be Mark IV
  10. RIP170
    RIP170 New Member
    Sep 9, 2021
    My idea with the motor so far is to swap the heads with gen VI vortec heads and comp cams 282 flat tappet, the cam setup was recommended by Richard Holdener
    Also i'm not 100 percent sure if it's a 1990 or 91 but i am sure it came from a 454 ss
