Connella08
We have the same model! Cool! Cant wait to see your finish. Do you have stock heads? Will you change them? Did you check out if the t tops leak? If they do, dont worry, with an ultimate set of tools you can fix it. Great project!
I do have the stock heads but aside of the original engine block, im doing an entirely new build. Its going to have the eagle 385 stroker kit, AFR heads, edelbrock intake, and a new 4bbl holley. The T-tops do leak so I'm probably going to have to get new gaskets.
