Give me Tractor Advice
Discussion in 'The BS Topic' started by gordonquixote, Aug 23, 2016.
  1. gordonquixote
    3,022
    11
    Jul 18, 2006
    Tallahassee, FL
    Looking at two Kubotas. (Similar deal with John Deere)
    3301 with front end loader and light duty 5' rotary cutter (bush hog). Includes $850 valve to allow for operation of a grapple/root rake on front. Quick disconnect loader.
    3901 same as above with medium duty rotary cutter.
    Both are hydrostatic 4-wheel drive and have several thousand in rebates.
    3301 $14,800
    3901 $17,100 (6 more hp than the 3301)
    Quick disconnect loader $5,450
    Med duty cutter $1,850 (cuts 2" diameter stuff)
    Light duty cutter $1,250 (cuts 1.5" diameter stuff)
    3301 package $22,971
    3901 package $25,939
    3301 0% for 84 months with 20% down is $249.71 per month (tax, insurance, etc)
    3901 0% for 84 months with 20% down is $281.65 per month, all in.
    I would use it to mow a 1.12 acre parcel that our building is on, use it for general 'shop' duties, and occasionally cut about 5 acres of grass and some light scrub at my mom's property.
    Am I crazy buying a tractor or should I chill out and just buy a nice zero turn mower?
    Random Internet picture of same rig:
  2. David79Z28
    1,278
    41
    Oct 22, 2009
    Greenville, TX
    Why not buy an older used one?
    I use a '79 39hp 230 Massey Ferguson to mow 13 acres, maintain my drive, etc.
    I use a old John Deere 5' cutter.
    Works great and they are a fraction of the price of a new one.
    Around the house and my shop I use a riding mower. It's easier to get closer with the riding mower.
    For your needs I'd go used.
  3. The Champ
    The Champ Veteran Member
    5,456
    1,081
    Sep 14, 2000
    MN
    As long as you realize that they've inflated the price of the tractor so that you get 7 years interest free...
    That's WAAAAAAAAAAAYYYYYYYYYYYYY to much tractor for cutting 1.12 acres.
    Even for 5 acres, that's a LOT of tractor.
    I hope you have a lot of projects that require the other implements if you are trying to justify the purchase.
  4. Twisted_Metal
    29,894
    2,676
    ^Agreed.
    How far away is your Mom's property? (Do you have to haul it there?)
    Can you write off depreciation as a business expense?
  5. Chevrolaine
    Chevrolaine Veteran Member Gold Member
    3,368
    194
    Aug 5, 2007
    Various barns in N. IL looking for chit.
    Buy the tractor, you'll never regret it. Shoulda been the first thing I bought when we moved to the farm.
    I'm sure your business could find d a use for it also.
  6. mickstan
    mickstan Veteran Member
    927
    Jun 11, 2012
    E'ville, IL
    I use a 1988 John Deere 318 for an acre. Noooooo problem with a 50" cut. You picked a heck of a machine for your needs. If you can afford it do it!
  7. Mike Bozung
    Mike Bozung Veteran Member
    144
    Jul 7, 2011
    muncy,pa
    That pic. of the Kubota looks close to mine. I have the L2900 model. It's very handy to use. I have a 7' scraper blade which does a great job in smoothing out any gravel / dirt road, in a hurry. Although I never used it ( because I don't have one) it has a hook up in the middle for a belly mower. I think that would be better than a brush hog. It does seem like a lot of money to mow grass. I bought my used and it's still in great shape. You might want to look into that, they are out there. I can say one thing, they hold their value.
  8. BLUE72CAMARO
    BLUE72CAMARO Veteran Member Lifetime Gold Member
    4,955
    317
    Mar 15, 2004
    Bunker Hill, IL
    So here's the questions I have Gordo.
    What transmission shuttle or hydro?
    Lift capacity of loader for both?
    What kind of finish are you looking for when mowing? Bush hog rotaries will not give you a lawn mower quality cut.
    Other uses with your business possible?
    I have a ford 1920 tractor that I use quite a bit around my place 8.5 acres. I don't do much mowing with it but I use the snot out of the loader. Mine is a shuttle shift which is nice compared to my dads 1710 with a typ. Manual transmission I would much prefer a hydro for doing loader work and mowing. I do not like hydros for ground engaging equipment though like disk, chisel plow, or planter.
  9. clill
    clill Veteran Member
    582
    82
    Jul 10, 2001
    Woodland, Ca. US
    I have had a couple similar Kubotas over the years. I had one with the belly mower and it was a pain in the ass. Current one has a rotary mower out behind and I mow several acres with it. Does it in have the time the belly mower did. You will love the Kubota and it will have decent resale.
  10. 77Z28454
    77Z28454 Veteran Member Lifetime Gold Member
    105
    13
    Aug 24, 2007
    Ontario
    I'd buy the 3901, it has the PTO horsepower to run more implements. I bought an L3400 new in 2010. I use it for all kinds of things around my place. I would suggest you make sure it has the skid steer quick attach loader and get a set of forks. The forks are so handy I can't even explain how many things I've used them for. I also have a box scraper that I find useful for dirt, driveway work etc.
    If you are cutting actual lawn I would get a rear discharge finish mower. I have one and it cuts the lawn really nice and is easy to take on and off the three point. I have brush hog as well but I use that for trails and clearing actual brush.
    [​IMG][/IMG]
    [​IMG][/IMG]
