Glove box door lock
Discussion in '1978 - 1981 Specific' started by rodebcada, Jun 25, 2020.
  1. rodebcada
    rodebcada 79zrod
    28
    Aug 25, 2013
    nc
    Is there any way to tighten the glove box door lock on 1979 Z? Mine works but has a lot of play in it.
    Thanks
  2. Gary S
    23,109
    1,105
    I've never had mine apart, but since it is removable, it is adjustable too. You need to pull it apart and see what it takes to tighten it or if something is broken, you need to replace that part.
  3. Twisted_Metal
    27,680
    1,300
    Play in the lock or play in the latch?
    The U-shaped catch inside the glove box has slots in the mounting holes so you can adjust it inward a bit.
    If the lock/latch is sloppy in the glove box door... The ring holding it in place can be tightened.
    I believe you need to pull the lock out first to tighten the ring to the latch.
    These two vids give good instructions.
    joeparamonkey likes this.
  4. Gary S
    23,109
    1,105
    If it is like my old Chevy pickup lock, the key needs to be in the lock to disassemble it.
  5. rodebcada
    rodebcada 79zrod
    28
    Aug 25, 2013
    nc
    problem solved. thanks again guys
