GM neutral safety swithch
Discussion in 'Electrical Systems' started by hot72rod, May 9, 2016.
  1. hot72rod
    3,019
    39
    Aug 9, 2000
    Phenix City Al / Columbus Ga
    I am playing with the neutral safety switch in my 73. Can any one tell me what each one of the plugs are for on the switch. I know there are 3 different plugs and I know one is a neutral safety and one is the back up lights, not sure what the last one is and I'm not sure which one plugs into which slot.
  2. 76_TypeLT
    6,394
    149
    Jul 26, 2008
    Houston, TX
  3. hot72rod
    3,019
    39
    Aug 9, 2000
    Thanks for posting that but it doesn't completely help.
  4. rchydzik
    897
    39
    Nov 13, 1999
    Colbert, WA USA
    The blades that look like this | | are the neutral safety switch. The ones that are side to side like this _ _ are the backup lights. If you are using the original harness, you can't get it wrong because the connectors only fit the correct spot.
