GM Power brake booster spec
Discussion in '1970 - 1973 Specific' started by 67johnny, Sep 17, 2021.
  1. 67johnny
    67johnny Veteran Member
    326
    28
    Apr 14, 2016
    vancouver
    Hey all!
    Didnt get much traction on this over in the brake section so thought I would give it a go here!
    The off-shore booster I was given has a non adjustable master cylinder apply pin that appears to be 2 and 9/16 long
    (including nub on inside end of booster).
    Whats the factory one measure up at?
    I dont have one of those H shaped adjuster tools.
    Have had issues before with brake drag.
    Compensating port was covered I believe.
    Dont need that again!
    So stupid they wont make them adjustable like back in the day.
    Looks like another case of off-shore close, counts and the lowest price is the law.
    Just another need to know deal.
    Any help appreciated!
  2. berg2695
    berg2695 Veteran Member
    567
    213
    Nov 13, 2011
    AUBURN, WA
    I was in the same boat recently so I stuck a small wad of Silly Putty in the master before bolting it up. When I unbolted it, it told me I needed to put a shim between the master and the booster to get the desired clearance. (.020" clearance I think. I can't remember for sure off hand.) I was using factory parts but was bolting a modified '77 booster to a '81 master. I cut a shim out of sheet metal that matched the base of the master. I figured washers wouldn't cut it.
  3. Twisted_Metal
    30,062
    2,782
    I had to shim one of those pretty repop boosters too.
    (Brakes wouldn’t fully release and we’re VERY hot within a couple of miles.)
    I used stainless steel washers but the diaphragm failed in a couple of years so I went back to my original booster, which had been painted.
  4. 67johnny
    326
    28
    Apr 14, 2016
    vancouver
    berg2695 likes this.
