GM SP383 or BluePrint 400?
Discussion in 'Engine Topic' started by ProjectCam76, Jun 7, 2016.
  1. boogie
    boogie Veteran Member
    235
    May 29, 2011
    louisiana
    Please do!
  2. BigEd36
    BigEd36 Veteran Member
    141
    Mar 14, 2010
    Auburn, IN
    Plus 1!
  3. Patrick73RS
    Patrick73RS Veteran Member Lifetime Gold Member
    1,704
    74
    Oct 1, 2004
    Montreal (Living in Houston)
    ^ + 2
  4. ULTM8Z
    ULTM8Z Veteran Member
    10,231
    967
    May 19, 2000
    Los Angeles
    Absolutely... at 1.2 hp/cu-in, a 350 will make 420 hp while barely trying.
    A 454 makes 545 at 1.2.
    Pretty smooth idle, probably 25 mpg hwy (I'm getting 27 now with my 350) and ~550 hp and probably an obscene amount of torque...
    Who freaking needs an LS at that point? I can reuse all my current EFI hardware for hassle free install... Sell my current setup to make up some of the cost..
    Yep this thing is definitely in my future.
  5. CNC BLOCKS
    CNC BLOCKS Veteran Member
    1,656
    30
    Oct 11, 2004
    NORTHEAST
    Blue Print Engines called me today. They are using a standard cam tunnel block and going 4.250 on the bore and 4.000 stroke and they said they sonic test everyone of those blocks.
  6. ToolGuru
    ToolGuru Member
    81
    15
    Aug 1, 2014
    Detroit, MI
    Finally! Somebody who gets it when it comes to the LS craze. Thought I was the only one. Don't get me wrong, the LS is a tech marvel. But people want to sell the traditional small and big block engines short and i don't get it.
  7. ULTM8Z
    10,231
    967
    May 19, 2000
    Los Angeles
    We'll if I were starting from scratch I'd probably go LS.
    But the big inch SBC makes more sense for my situation since I don't want to tear out my existing EFI system.
  8. muscl car
    23,523
    1,878
    Jul 8, 2001
    Gallatin Tennessee
    Either a 434sbc or 454sbc would be an awesome choice for your Camaro
  9. 76_TypeLT
    6,394
    149
    Jul 26, 2008
    Houston, TX
    Nice sig, LOL
    You ever see my 76 LS project thread :D
  10. badazz81z28
    21,330
    1,543
    Alabama
    For a car that I drive on the street pretty often, I rather have my multiport fuel injection LS engine.
    I would only run a carb'd engine on a dedicated strip car. Each has their place for me.
    $7600 isn't bad for a 454 short block, much better deal then buildings a 383 or 406. If you have the intake, carb, and accesories, easy drop in for sure and only be in it about $8k.
    Btw Tool Guru, 575hp 454ci....LS 530hp 346ci.....people are making 700hp+ stroking LS3s. The cubes make power for sure, but it was the BBCs cylinder heads that feed big power. Something the LS cylinder head still leads on over the SBC simply improved technology.
