GM "Update" for Your 4-pin HEI distributor
Discussion in 'Tips 'n' Tricks Topic' started by sandlapper, Mar 14, 2021.
  1. sandlapper
    sandlapper Veteran Member
    649
    222
    Oct 9, 2020
    SE CSA
    We all know the GM 4-pin HEI (mid-seventies thru early-eighties and universal performance favorite). We also know it's near dead-nutz reliable; but that their modules occasionally fail and that's often attributed to it becoming overheated. Of course we also know to ensure the module is installed with a good heat transfer/thermal paste (such as Arctic Silver) between it and its mount pad on distributor base. We know how heat is mortal enemy of most electronic circuits; and that reducing heat can often extend electronics' useful life. Well ...
    Years ago, GM removed the module from inside-on that very hot distributor housing and mounted it (and coil) remotely.
    You can easily relocate Your old module as well... where it'll run much cooler.
    Ignition Control Module Heat Sink GM pn 10474610 (trucks 94-2004) < $12 @ RA
    https://www.rockauto.com/en/parts/acdelco,10474610,ignition+control+module+heat+sink,11323
    drill new holes in new heat sink to fit Your 4-pin module, bracket it atop motor or on firewall etc, extend-sleeve your pickup & coil wires, mount Your module to new heat sink w/ thermal paste.
    :bowtie:
    danbrennan, mrluckies, RS1979 and 2 others like this.
  2. biker
    biker Veteran Member
    3,454
    1,545
    Dec 7, 2014
    Thanks for this! Definitely will do the mod when car is out of storage jail. Soon I hope.
  3. Fbird
    5,531
    1,494
    Feb 12, 2011
    atlanta, ga
    do NOTE the difference between THERMAL paste and Dielectric grease!!!! NOT the same.
  4. John Wright
    15,194
    392
    Aug 9, 2002
    Rustburg, Va
    Another module killer is a dead spark plug or one with a spark plug wire that is arcing to ground.
  5. cadillac_al
    cadillac_al Veteran Member
    977
    128
    Apr 22, 2015
    Maine
    Funny thing is, I have never bought a module that didn't come with dialectic grease. I wonder why the manufacturer doesn't give us thermal paste?
