Going out of my head on a fitting, need some help please
Knuckle Dragger
Mayor of Simpleton
16,865
Waddell AZ
I bought a fuel rail from Ebay for my Blazer project. I'm using an aftermarket manifold and I had to try two different fuel rail sets to get something that will work. I need to put a push connect fitting in the end of on rail and they are ORB fittings on the end of the rails. I measured and the closest match was the -10AN ORB, it was too big. I bought a -8AN ORB and it was too small. I have no idea what the hell I'm looking for now. I'd prefer a fitting to go to the 3/8 push connect but at this point I'll take a plug and drill and tap a NPT hole if that's that it takes.
I'm not sure how well I explained that, let me know if I can clarify anything. Any help is appreciated.
Pictures in case it helps.
Fbird
6,372
atlanta, ga
camcojb
2,610
Wilton, Ca. USA
A lot of the fuel rail and coolers built outside the US are metric. M22 is a common size for those. You might use some digital calipers set to metric to measure the threads.
Knuckle Dragger
Mayor of Simpleton
16,865
Waddell AZ
I did but kept looking at the standard sizes, 22mm seems about right. I didn't think about metric stuff. The plan is to repurpose one the the -6AN adaptors, drill and tap for NPT threads and use a readily available adaptor. Drill, tap and adaptor should be here today.
