Good head gaskets for aluminum?
bitchin'71SS
397
Poughkeepsie, NY
Can i get a recommendation for a quality composite head gasket for aluminum heads on an OEM block?
This is for a mild NA street 355 sbc I'm building. Just got the new Eddy E-Street heads in the mail and cleaned up all the old head bolts, realized I probably shouldn't use the stock replacements that came in my gasket set because they were most likely designed for iron heads.
it's a gen I 350 sb with 4.030" bores.
Thinking about these felpro performance gaskets.
http://www.summitracing.com/parts/FEL-1010/
CR would be at 9.82:1 with these and the 64cc eddies:happy:
:bowtie:
cmonson
4,134
Calgary, Alberta
How far is your piston below deck. If close to .025 then felpro 1094 are a great choice. I just used 1094s on a eddy rpm head build and so far so good.
Get your quench to .040 as close as you can. 1094 is a .015 shim.
hhott71
R.I.P 11/19/18
14,377
Joplin Mo. 64801
:bowtie:
The Felpro 1094 works just fine with aluminum heads and stock deck height cast iron SBC block.
You will need hardened washers under the headbolts, they are aprox 1/8" thick.
bitchin'71SS
397
Poughkeepsie, NY
It didn't even cross my mind actually, thanks guys. I'll pick up some of those, is that something i could get grade 8 at the hardware store or would I be better off getting from a speed shop?
Would the 1/8" washers require new bolts that are 1/8 longer than stock? I was hoping to re-use the original bolts since I already cleaned them all up..
If I have to I'll get new aftermarket bolts but they're $$
Damon
12,939
Philly area
Buy an aftermarket set. Doesn't need to be an expensive aftermarket set either. Get the ones with undersized 6 or 12 point heads. They work best- aftermarket aluminum heads often have a few bolts you can't get to with a full size 5/8" socket like a stock head bolt uses. And almost all aftermarket head bolt sets come with anti-gall washers like aluminum heads need. Trust me.
bitchin'71SS
397
Poughkeepsie, NY
Yeah, it looks like I'll be getting new bolts. ARP #134-3601
I measured the deck clearance at TDC with my vernier caliper, it was between .025 and .030 wherever I checked. So if ideal quench is .040" that 1094 .015" felpro should work perfectly. Thanks for the recommendations guys.:bowtie:
Also, that brings the static compression up to 10.4:1, which is pretty awesome but I don't really want to go any higher than that on this engine.
