Grinding noise on start up
Discussion in 'Troubleshooting & Diagnosis' started by Daniel I, Jun 29, 2019.
  1. Daniel I
    Daniel I New Member
    16
    Jun 29, 2019
    Every time I start my car I get this nasty grinding type noise when it just cranks over, what would be the cause of this?
    You can view this video to listen to the noise
    V
  2. Twisted_Metal
    28,122
    1,567
    My guess... The starter isn't disengaging immediately.
    I would check the teeth on the starter gear and flexplate to be sure they aren't chipped and worn.
    If they still look good, it may be a weak return spring between the solenoid and starter.
    If the starter is really old and gunked up, it may just be crud in the spiral splines preventing it from disengaging properly.
    Stock type starters aren't very expensive. It might be worth replacing if the teeth look bad.
    hubedobeedo likes this.
  3. dave@ztech
    4,356
    966
    Mar 27, 2016
    NY
    Also check to make sure the bolts holding the starter are not loose , letting the starter move , and get out of line, had one do that, and then snapped the block where it bolted on, really ruined my day, HAA HA
    BC_Homegrown and hubedobeedo like this.
  4. Daniel I
    Daniel I New Member
    16
    Jun 29, 2019
    Ok, thanks for the response, I appreciate the help!
  5. Daniel I
    Daniel I New Member
    16
    Jun 29, 2019
    Thanks for the response, but damn that’s crazy, is something like that repairable?
  6. Gary S
    23,357
    1,249
    The starter is easily repairable with a low priced rebuild kit. However, if the gears on the flywheel/flexplate are chewed up, that isn't so easy to fix.
    Before using that starter anymore, pull it off and inspect it. While it is off, look in and see what the teeth on the flywyeel/flexplate look like.
    A rebuild kit like this should fix all the little problems with the starter.
  7. dave@ztech
    4,356
    966
    Mar 27, 2016
    NY
    When it broke the starter from the block, I removed the solenoid from the starter, and tied it off to the fender, and push started it, thank god for high compression, HAA HA, just had to have it roll and it would start when I popped the clutch , just had to park on a slope everywhere , HAA HA , yours sounds simple, just get it off like Gary suggested and get a look at it. Easy fix usually
  8. bourbon_scotch
    2,748
    244
    Jan 10, 2003
    USA
    sounds like a old or bad starter
  9. mech393
    mech393 Veteran Member
    870
    31
    Aug 9, 2003
    belvidere illinois usa
    if you try everthing else and it still grinds you may have to shim the starter also you may have to count the teeth on the fly wheel and then check and see if the teeth on the starter drive is a match to the fly wheel
