grounding - wiper motor
Discussion in 'Troubleshooting & Diagnosis' started by Chuck71RS, May 26, 2021.
  1. Chuck71RS
    1,726
    335
    Nov 24, 2012
    Houston, Texas
    Is the motor suppose to ground to the firewall?
    The thick grommets in the three fastener locations offset it from the firewall
    I don't remember a lead grounding motor the firewall
    The motor diagrams in the 1971 Fisher manual show a ground symbol downstream of a circuit breaker. It looks like the lead coming off the circuit breaker grounds to the motor housing.
  2. Jodi
    Jodi Veteran Member
    824
    542
    May 22, 2019
    Not sure about '71 but on my '73 one of the grommet has a ground strap just like the pic. below.
    Chuck71RS likes this.
  3. Chuck71RS
    1,726
    335
    Nov 24, 2012
    Houston, Texas
    Thanks Jodi. One of the grommets with the last 71 replacement motor has the ground strap that yours has.
    So far the 2017 installed motor and two warranty replacements stopped working. The last failure was Sunday. A third replacement is ready for me.
    Have been going through every little detail from power leaving the wiper fuse to grounding.
  4. wnmech
    wnmech Veteran Member
    1,306
    268
    Jul 20, 2014
    grand prairie tx.
    C0E60F6B-276F-4430-801C-1BF206D6E9BD.jpeg B976C8A8-9812-4AF8-8AD8-18BDD5B7BD6A.jpeg B976C8A8-9812-4AF8-8AD8-18BDD5B7BD6A.jpeg
  5. wnmech
    1,306
    268
    Jul 20, 2014
    grand prairie tx.
  6. Chuck71RS
    1,726
    335
    Nov 24, 2012
    Houston, Texas
    Rick:
    In your second posting, I see the three motor connections are sorta vertical. The LBL wire goes on the bottom, double black-yellow in the middle and the single solid black at the top. The long Double black-yellow provides the power from the fuse and the short length sends power to the pump.
    Your wiring looks to be factory original by the wiring colors
    Below is from the 1971 Fisher body manual for the round motor, which is hidden wiper. Standard wipers have a square motor
  7. wnmech
    1,306
    268
    Jul 20, 2014
    grand prairie tx.
    Chuck
    Sometime tomorrow I will throw a new fuse into my fuse block and start checking for power on my wiring and let you know if anything matches your car.
  8. bkmont
    bkmont Veteran Member
    1,239
    125
    Nov 14, 2010
    Pensacola, Florida
    My original 1970 wiper motor. See the ground strap.
  9. bkmont
    1,239
    125
    Nov 14, 2010
    Pensacola, Florida
    Nobody asked about the hesitation in low speed:)
