gt45 turbocharger
Discussion in 'High Performance Modifications' started by camaro19791000, Jun 9, 2010.
  1. camaro19791000
    camaro19791000 Veteran Member
    103
    Feb 28, 2009
    El paso Texas
    Has anyone ever strapped a gt45 turbo to their 2nd gen??or has anyone ever turbo charged their 2nd gen??? if so hows are you running your set up w/intercooler or w/o twin turbos?? what carbs??? can i use a qjet if i completly enclose it in a air box?
  2. Turbo T/A
    Turbo T/A Veteran Member Lifetime Gold Member
    4,207
    Apr 8, 2002
    Ottawa, Ontario, Canada
    search.....
  3. anesthes
    anesthes Veteran Member Lifetime Gold Member
    868
    Jun 17, 2009
    Salem, NH
    Heh. the first time I saw pics of yours I almost pooped myself.
    Had I built a better lower end..
    -- Joe
  4. dcozzi
    dcozzi Veteran Member
    4,234
    1,202
    May 1, 2002
    Phoenix, AZ
    A GT45 should make around 800HP with 8.5:1 compression and a 400cu/in V-8. This is assuming, conservatively, HP losses and pump gas. A very very streetable motor with a little lag. Twins would be even better.
    Not cheap to do right with quality parts like a Dart block, forged bottom end, intercooler, turbocharger, wastegate, headers, exhaust, intake tubing, boost referenced carb, etc, etc, etc............................................................
    I priced out a pair of turbos with everything except my labor and it was around $7800.
    Search the site. There are a few who have done it like TurboT/A (SBC) and IIRC Louich (BBC). Very fast rides!
