Gulstrand suspension parts
Discussion in 'Swap Meet Section' started by kamaro kid, Apr 30, 2020.
  1. kamaro kid
    kamaro kid Member
    36
    Oct 24, 2017
    North Cacalacki
    Gulstrand Engineering springs for Gen 2 F body. Front coils 13" free height, 8 coils, .745" wire diameter, checked 720 lb/in on one test press, 740 lb/in on another tester. Rear leafs are GS12-001A, 270 lb/in. Low arch and 2nd leaf wraps front spring eye. 4 Bronze eye bushings are needed, common oilite bushings .75" o.d. by .50" i.d. by 2.25" long or 2 shorter sections will work. Includes front spring perches modified for anti-squat, cross bolt raised 1". Suggest nylon washers on each side of front spring eye to reduce noise on the street, old ones were worn out. These were designed to be used with a .75" to 1.0" front swaybar and no rear bar. I will include a 1" front bar but it will require sandblasting and new bushings/end links. These will be super firm on a street car, used on a track trials/hillclimb car with great success. Local pickup in the Charlotte, NC area will save a lot of freight on these heavy pieces. $150 for all plus the ride. I can also include a set of 4 solid steel eccentric front upper control arm bushings with grease fittings.
  2. Tpichevy
    Tpichevy Veteran Member
    519
    16
    Jun 21, 2016
    Boise id
    Dang wish you were closer! Great deal for sure.
  3. John Wright
    15,293
    433
    Aug 9, 2002
    Rustburg, Va
    I have 700# springs w/ 1.25" front bar on mine, they aren't all that bad on the street.
  4. kamaro kid
    kamaro kid Member
    36
    Oct 24, 2017
    North Cacalacki
    bumpity bump
  5. mark wagner
    mark wagner Veteran Member
    2,131
    19
    Jul 31, 1999
    Saylorsburg Pa. USA
    I picked up a pair of big block springs, supposed to be Guldstrand, what kind of drop do they have? I have 2 inch drop leafs for the rear
