Hard Brake Pedal Suggestions
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by JRowe, Aug 8, 2020.
  1. JRowe
    JRowe Veteran Member
    628
    Sep 3, 2000
    Tavares, Florida
    My 73 Z28 sat for a few years and the brake fluid leaked out. So I put all new brake lines in, new master cylinder, new booster, wilwood D52 brakes up front etc. Bleed the brakes and now I have a hard pedal. All four brakes seem to work. The back drums appear to work. I took the drums off and all the pads moved. I have spun the front wheels and had someone hit the brakes and the all stopped but I still have a hard pedal. Bleed the car a few more times. Tested the booster and it seems okay. The proportioning valve does not appear to be off center. Did not change it and the wheel cylinders have not been changed
    Any suggestions on what else I should look at? Thanks for any suggestions
  2. ULTM8Z
    ULTM8Z Veteran Member
    9,713
    713
    May 19, 2000
    Los Angeles
    Could be the piston size in the master is not correct for the rest of the system.
    Did you get everything as a kit?
  3. JRowe
    628
    Sep 3, 2000
    Tavares, Florida
    No. But I got the master cylinder from NPD. So I think it should be right.
  4. ULTM8Z
    9,713
    713
    May 19, 2000
    Los Angeles
    If the master cylinder piston is too big it'll definitely give you a hard pedal.
  5. l16pilot
    1,933
    171
    Dec 13, 2004
    Hurlock, MD, USA
    I had what sounds like a similar situation several years ago with my 70Z. Installed all new brake components and brakes bled and worked well, but pedal was very hard. Turned out my new repop booster was bad. Installed a new repop booster and all worked as normal. Just a thought...just because a part is new does not mean it's good.
    Fbird likes this.
