Hard starting
Discussion in 'Troubleshooting & Diagnosis' started by Howard Buckner, Aug 14, 2021.
  1. Howard Buckner
    Howard Buckner Member
    43
    8
    Oct 8, 2019
    I have a 71 402 that is completely stock. Have had the carburetor rebuilt and the car runs well. If i don't use the car for a day, when i go to start it, i have to physically pump the pedal at least ten times or more to get gas into the carb so it starts. This is after i depress the pedal to set the choke. Is this a symptom of the choke not being set up right or a leakdown in the carburator?
  2. xten
    xten Veteran Member
    4,391
    3,415
    Sep 24, 2014
    Pittsburgh, Pa.
    Sounds like the diaphragm in the fuel pump letting the fuel drain back. Mine did that
    MChamp likes this.
  3. MChamp
    MChamp Veteran Member
    298
    77
    Jun 6, 2021
    north carolina
    yessir. 2nd diaphragm.
  4. Howard Buckner
    43
    8
    Oct 8, 2019
    if that were the case, wouldn't i see fuel leaking from the weephole (if the pump has one)?
  5. tom3
    tom3 Veteran Member
    13,701
    1,243
    Aug 1, 1999
    ohio
    Is this a quadrajet carb? Pull the air cleaner off and look for a shot of gas when you pump the pedal. Does the choke butterfly close?
  6. 73 Z
    1,172
    73
    Jun 9, 2007
    Los Angeles, Ca
    Or Fuel in the oil, smell the oil dipstick. Does it run well at idle, and under load?
  7. Twisted_Metal
    30,064
    2,787
  8. rocket dawg
    rocket dawg Veteran Member
    485
    60
    May 5, 2015
    Grand Rapids Mi
    I put the wrong fuel pump on and it drained back repeatedly. AC Delco pumps for me until recently. I went EFI.
  9. Vettenick
    Vettenick Vettenick
    350
    67
    Jul 17, 2019
    How old is that pump? One way to find out if it is drain back is to block off or pinch the fuel supply line after you gave run it. If after your time period, it starts immediately, then you know it's drain back.
  10. Howard Buckner
    43
    8
    Oct 8, 2019
    great idea
