head bolt sealer
Discussion in 'Engine Topic' started by HULKZ28, Jun 6, 2015.
  1. HULKZ28
    HULKZ28 Veteran Member
    1,572
    Oct 15, 2005
    Jeffersonville NY USA
    im using arp head bolts on my 422 alum head motor..arp says to use thread sealer or assy lube on the threads..don't certain bolts need silicone to seal out coolant??
  2. Dogwater
    Dogwater Veteran Member
    926
    Dec 23, 2010
    SanAntonio Tx
    Yep. Use Permatex thread sealant. Small white tube, might need 2 of um.
  3. BIG CHEVY
    BIG CHEVY Veteran Member
    358
    Oct 28, 2011
    dallas ga.
    i have arp bolts. i used permatex 2 per advice from this forum on them. there are ZERO leaks. glad i did. thats just my experience. but i did use a lubricant they sent with them under the heads of the bolts and each side of the washer. make certain the washers are turned correct.
  4. Dogwater
    926
    Dec 23, 2010
    SanAntonio Tx
    Don't put any lube on the threads when using thread sealant!!! The sealant itself will be the lube. Dig??
  5. COPO
    20,586
    2,304
    I use Permatex 2.
  6. WebbGM
    WebbGM Veteran Member
    273
    Jan 5, 2015
    Pelham Ga
    repair
    Liquid Teflon. Used it for years no problem acts as a lube also
  7. Damon
    Damon Veteran Member
    12,939
    23
    Nov 16, 2000
    Philly area
    For a million years I've used Indian Head Gassket Shellack on the threads. It's similar to Permatex #2.
    The head of the bolt and the washer need LUBRICATION, however, to assure proper torque. You can use motor oil or the lubricant that ARP recommends, just make sure you use their torque specs depending on which you use.
    If in doubt, use 65 ft/lbs in 3 steps. 35, 55 and 65.
  8. HULKZ28
    1,572
    Oct 15, 2005
    Thanks guys
  9. joeEZ
    joeEZ Veteran Member
    374
    May 29, 2001
    Memphis, TN USA
    At Napa, Permatex pn 765-1188. Thread sealer with Teflon. Comes in a 4 oz.container with applicator brush. Use the ARP lubricant on both sides of the washer and under the bolt head as mentioned above.
  10. rocket dawg
    rocket dawg Veteran Member
    425
    50
    May 5, 2015
    Grand Rapids Mi
    Thats the stuff I used for years---no leaks ever--
