Headers best size for my motor
Discussion in 'High Performance Modifications' started by joer, Jan 7, 2013.
  1. joer
    joer Veteran Member
    245
    Sep 25, 2008
    East Brunswick, New Jersey
    I'm taking off my 2-1/8 headers, down sized the motor a little. Right now making around 560hp. Looking at either 1-7/8 or 2inch tubes. Just asking you big block guys what you think. My choice of headers going back as always been Hooker. Appreciate your advice.
  2. 77 cruiser
    77 cruiser Veteran Member
    589
    36
    Nov 17, 2006
    Frostbite Falls MN
    1.75 should be all you need.
  3. Damon
    Damon Veteran Member
    12,939
    24
    Nov 16, 2000
    Philly area
    Big enough to cover the port and hold a gasket.
    I'm using the Hooker Super Comps in my truck (same crazy-big primaries as you are taking off). Only reason I went that big was to cover the HUGE exhaust port on my AFR heads, not because I needed anything that big for the HP level I'm making, which is probably not even as much as you are with your "downgraded" combination.
