Headers
flowjoe
Moderator
8,146
SoCal
'71 Camaro w/ SBC, PS, AT and factory AC - what headers will fit? Street use no track time.
mjoc
3,534
Sherman Oaks, Ca
Dynatech, musclemaxx is what i use. I love there four bolt collectors will never have to replace collector gaskets and the have huge flanges.
Mike
71cmro
1,395
Beavercreek, OH USA
Summit ceramic coated work and stay looking good for a long time and are pretty cheap. You do have to massage the passenger floor board a little for flange clearance. You need to remove the starter to install. I installed on the drivers side from underneath the engine. Installed on the passenger side from top of the engine. Suggestion is to start the passenger side bolt closest to the fire wall first but don't tighten down but half way. Then install all the rest of the bolts loose prior to tightening any of them down.
mjoc
3,534
Sherman Oaks, Ca
Compare the quality of the summit headers to the higher priced unit and you will see like everything else you pay for quality.
Mike
flowjoe
Moderator
8,146
SoCal
Mike
And these clear your AC suitcase?
