Headers
bfmgoalie
3,392
Gansevoort, New York
These are the headers on my car. Notice how the pipe on the flange shrinks. What's that all about?
natzx7
40
St Petersburg FL
I believe I have the same ones. From what I can tell, it's when you don't need the tube diameter due to a milder motor, but need to match the exhaust port size at the head for better flow. Saves installation woes and space in the engine compartment. I've resolved this issue by ordering a set of 2 1/4" primary Lemon's headers for my next motor. 15 week lead time and $3000 ! 🤪
32,371
No significant shrinkage... The ends are actually expanded
They were probably sold with a measurement on the expanded ends to make them seem like larger primary tubes.
G72Zed
4,661
That looks like the manufacturer used a flange made for a large port - 2.250 primary pipe and just expanded the pipe to fit better.
That is not a "stepped" header.
danbrennan
5,363
Brighton, MI
Yeah, I guess if they were stepped headers the tubes would get bigger as the distance from the exhaust port increased. But stepped headers was my first thought, too.
Increasing velocity at lower RPMs where exhaust flow isn't much limited is all that occurs to me as an advantage of necking the header down. But I would think that would limit higher RPM flow.
