Headliner install question about bow clips
Discussion in 'Interior Restoration' started by spinedoc, May 23, 2021.
  1. spinedoc
    spinedoc Veteran Member
    251
    16
    Jan 19, 2001
    Erie, PA USA
    Installing headliner in my 70. I put the OER replacement clips into the roof, then tried to snap the bows in, but the lips are so tight, I can't get them in. I tried little Vaseline, no luck.
    Any ideas or tips? I feel the OER clips are too tight. I have had bad luck with OER products before. Any other brands might be better?
    Thanks for the any help.
  2. 1970Camaro
    1970Camaro Veteran Member
    712
    14
    Jul 20, 2000
    Reseda CA
    Try installing them on the bows first, then slide them into the rectangle slots in the roof
    dcozzi and badazz81z28 like this.
  3. COPO
    20,879
    2,467
    Do what 1970Camaro says.
  4. spinedoc
    251
    16
    Jan 19, 2001
    Erie, PA USA
    The clips have to be twisted to get them into the roof. Can this be done with them installed on the bows?
    Thank you
  5. 1970Camaro
    712
    14
    Jul 20, 2000
    Reseda CA
    They shouldnt have to be twisted, the slots on the roof should be a rectangle slot with one end open. Can you post a pic of what you have?
  6. COPO
    20,879
    2,467
    See at 8:35
  7. spinedoc
    251
    16
    Jan 19, 2001
    Erie, PA USA
    Mine aren’t T shaped, so I can’t do that
  8. McCune
    McCune Veteran Member
    1,329
    329
    Aug 22, 2015
    st.george utah
    You sure you have a 70 roof?
  9. spinedoc
    251
    16
    Jan 19, 2001
    Erie, PA USA
    Good question. Far as I know? Did 70 have the T shaped slots only?
  10. McCune
    1,329
    329
    Aug 22, 2015
    st.george utah
    Can you get a better picture of the whole roof underside?
    badazz81z28 likes this.
