Heater blower motor
72camarolt
my blower motor has quit working and was looking into installing new one. Any tips on install and what brand would be best. non ac car
doug m
724
after install before you button things up turn the fan on to see if anything is rubbing.
32,118
The squirrel cage is a different depth on cars with A/C so make sure you get the right one if you're buying an assembly (motor & fan).
I think I used the Four-Seasons unit from Rock Auto and have had no issues with it.
They sell GM units too.
mallard
2,230
SK, Canada
FWIW, on many GMs of that era, the AC heater motor will fit on non AC cars and has more “blow”. You can wrap tape around the motor to cover the vent hole.
Gary S
24,774
I don't believe you will find a rubber cooling tube or hole on a non-A/C motor. That cooling hose is for cooling in the Summer when the A/C is running to prevent the motor overheating in hot weather. A non-A/C system won't be used in hot weather so cooling isn't an issue.
mallard
2,230
SK, Canada
I believe you’re right on that but the ac motors commonly do have that hole. But as they generally have more power than non ac motors we commonly replaced the non ac motors with ac motors on GMs as they usually fit. Just wrap tape around the motor to cover that vent relief hole.
jurquhart
71 Z28/RS
Feb 11, 2011
202
I have a working blower and squirrel cage from a 71 Z non A/C car I may not be using...
Let me know if you decide to go that route and I will see if the kid will part with it.
