Heater hose replacement? ???'s
Discussion in 'Body Restoration' started by dickeymoore, Jul 31, 2017.
  1. dickeymoore
    dickeymoore Veteran Member
    116
    16
    May 7, 2010
    Atlanta,Ga.
    I have a 1974 Camaro Z28 and I need to change out the heater hoses from the engine to the heater core but I can only see one fitting on the heater core how do I get to the other fitting on the heater core do I have to take the whole dash out or what? THANKS
  2. Zspoiler
    Zspoiler Veteran Member
    4,158
    501
    May 6, 2012
    Federal Way, Washington
    The heater core inlet /outlet come out of the firewall near the engine.On non AC cars. To the water pump and to the intake manifold. 5/8 ans 3/4 are the hose sizes. You can cut to fit the way you like. I use a Chevelle hose bracket.
  3. Green hornet
    Green hornet Veteran Member
    2,028
    479
    Oct 11, 2015
    North Bay, CA
    Both should be sticking out of the fire wall. Post a pic if you can.
  4. CorkyE
    11,507
    964
    Did you remove the inner fender on the passenger side?
  5. dickeymoore
    116
    16
    May 7, 2010
    Atlanta,Ga.
    So I have to remove the inner fender on the passenger side? THANKS
  6. CorkyE
    11,507
    964
    Take a flashlight and follow the hose, you should be able to see where it connects to the heater core, but I can reach mine with inner fender in place. Mine is an A/C car.
  7. dickeymoore
    116
    16
    May 7, 2010
    Atlanta,Ga.
    What year is your Camaro and is it the same as my 1974 Camaro
  8. CorkyE
    11,507
    964
    I have a 79 with a/c.
  9. dickeymoore
    116
    16
    May 7, 2010
    Atlanta,Ga.
    So is the 1979 the same as the 1974 with AC? THANKS
  10. 75Motion
    75Motion Veteran Member
    366
    8
    Jan 26, 2008
    Ohio
    Took a couple of pictures of my 75 with out air.
    [​IMG][​IMG]
