Hedman Elite Heavy-Duty Headers 67278
Discussion in 'Engine Topic' started by sam73, May 24, 2021.
  1. sam73
    sam73 New Member
    22
    Oct 29, 2015
    Haskell
    Just installed a set of Hedman 67278 on my 73 RS. Not sure I like the fit on the driver side from the underneath. The collector is pointing slightly down, rather than running parallel with the floor board. Look the pic from the underneath and you can see the difference between the right and left side. I called Hedman. Explained the situation and also sent pictures. DavidC at Hedman agreed with me that the driver side is hanging slightly lower that the passenger side. DavidC stated that there was nothing his company could do to resolve this issue. Just the way it is. Your opinion?
  2. Rosster
    Rosster Veteran Member Gold Member
    612
    311
    Mar 1, 2020
    Completely unacceptable! I’d ship them back (on their dime). Obviously they don’t give a crap about quality if they just blew you off like that!
    Zstar likes this.
  3. Green hornet
    Green hornet Veteran Member
    2,027
    477
    Oct 11, 2015
    North Bay, CA
    I put a set of Headman 68278 on a few years ago. Here’s a photo of the fit.
  4. Crazy4camaro
    Crazy4camaro Veteran Member
    469
    267
    Dec 30, 2015
    Greenville SC
    Send them back...
  5. camaro71/holland
    1,518
    207
    Aug 27, 2003
    The Netherlands
    Put a level across the top of your intake. On your 2nd pic it looks like the left/driver side of your transmission pan is hanging lower too.
  6. Zstar
    Zstar Veteran Member
    2,617
    892
    Mar 23, 2014
    Ocala, Florida
    I had this same problem with the same headers on my 73. I have an M21. The cure was to install a new rear transmission mount. Problem solved. You may also have a problem with your left engine mount.
  7. sam73
    sam73 New Member
    22
    Oct 29, 2015
    Haskell
    Holland--Zstar, you are correct. Looking at the pics, the transmission is hanging lower on the left. I will be in the shop tomorrow evening to investigate. I am surprised that the tech at Hedman did not see this. As noted, an issue with the motor mounts or transmission bracket/mount. Thanks guys
