Vettenick
Vettenick
- Jul 17, 2019
- 421
Adding an MSD can only benefit your vehicle. That being said, you need to go back to basics, because the MSD will not fix your issue. What RPM does this issue occur? What kind of fuel pump set up do you have. If your fuel supply is insufficient, your engine will tend to "float". When the issue occurs, does it seem to slow down, then pick up slightly, and then slow down again? Sort of like a mild bog.
