help back spacing
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by jake73, Nov 28, 2009.
  1. jake73
    jake73 Veteran Member
    124
    Aug 25, 2005
    spanaway WA
    i got a good deal on craigs list torque thrust II 17's from a guy off craigs list who said he pulled them off his 70 camaro. they wanted $600 dollers, i got them for $500, he said you only needed backspacing for the back rims, but i went to put them on my car and thier rubbing on the front and back, so can i get backspacings for the front and back and how big can you get them in because the back looks like it might need 3", or should i try to get my money back? All 4 are 17 X 9.50. These should fit right? Front and back? How much are backspacings?
  2. jake73
    124
    Aug 25, 2005
    spanaway WA
    Anyone?????
  3. QUAKE_WARS
    QUAKE_WARS Veteran Member
    2,313
    315
    Dec 19, 2008
    Back spacing is from the mounting pad of the rim to the lip edge of the rim. measure from back of rim.
    Your B/S for 9.5 rims should be 5.5 to fit correctly.
    Tell us what your B/S is when done checking.
    you may need spacers, or adapters
  4. jake73
    124
    Aug 25, 2005
    spanaway WA
    Definetly need backspacing. on all 4 rims just worse in the back. When the rim is sitting flat on the ground 3 rims measure 7 1/2 inches to where the bolts on the rim go through the other is 7 inches and it fits with out rubbing but only by a 1/16 of an inch maybe on the front
  5. Hoot
    Hoot Veteran Member
    1,475
    Jul 12, 2008
    Greenville MS
    Your asking about wheel spacers. These are used to move the wheel outwards away from the axle.
    Backspacing is the measurement from hub to edge of rim like this.
    Take a measurement like above picture then we can help you. Wheel spacers arent the safest things to use. Be careful if you need too wide. Studs snapring and wheels coming off at any speed is not healthy.
  6. jake73
    124
    Aug 25, 2005
    spanaway WA
    OK I measured it like that and 3 of the rims are 6 5/8 and 1 is 6 1/4.
  7. marc_b
    marc_b Veteran Member
    175
    Sep 30, 2007
    Livermore, Ca
    I would try and get your money back. 1/2 inch spacers are the thickest you can get. you may be able to get the rear to fit with spacers but I can't see the front fitting.
  8. jake73
    124
    Aug 25, 2005
    spanaway WA
    Anyone 2nd that? Dude said he just took them off his camaro, wich now that I tried them on My 73 camaro I dont believe. Even had the lug nuts. Why wouldnt you believe him he had the lug nuts
  9. jake73
    124
    Aug 25, 2005
    spanaway WA
    The back rims are going to need a whole lot more than a 1/2" spacers
  10. QUAKE_WARS
    2,313
    315
    Dec 19, 2008
    He may have lied to you. Did you see them on his car before purchase??
