Help Identifying fuel lines on tank
Discussion in 'Troubleshooting & Diagnosis' started by bazookatooths, Sep 26, 2018.
  1. bazookatooths
    bazookatooths Member
    37
    Apr 25, 2018
    OKC OK
    Was looking through my manual and cannot find a good diagram 71 camaro
    Passenger
    Center
    Driver
    pass=fuel feed, not sure other line , center=???? ,Driver line=charcoal line
  2. bourbon_scotch
    2,748
    244
    Jan 10, 2003
    USA
    Boy your not kidding about no diagram, i need this info too. I think i labeled mine when i took it apart, should probably go look under my car....
  3. bourbon_scotch
    2,748
    244
    Jan 10, 2003
    USA
    Ok, i drew this diagram. I think it's right but it would be nice to have someone back me up...
    hubedobeedo likes this.
  4. bazookatooths
    37
    Apr 25, 2018
    OKC OK
    Ahh so all those lines are vent lines, whats the rectangle do that they all connect too? I plan on updating my Fuel Tank and the new tank has Inlet,Outlet and Vent, and I have been trying to figure out how i'm going to hook up the vent line. Maybe just put a filter on it, or a one way valve?
  5. bourbon_scotch
    2,748
    244
    Jan 10, 2003
    USA
    All i can find out is that it's called a SEPARATOR ASM.
    No idea what it does or why its there.
  6. NorCal_71
    NorCal_71 Veteran Member
    390
    15
    Jul 7, 2008
    Santa Rosa, CA
  7. brye
    brye New Member
    26
    Apr 10, 2018
    Plugged the 3 extra holes with vacuum plugs and installed a vented gas cap. Thats the only way to go unless you are trying to stay factory.
    bazookatooths likes this.
  8. blue 396
    blue 396 New Member
    Feb 21, 2015
    Sydney (Aus)
    looking at the vent lines could one of these be used for a return line? I am about to install a Holley Sniper fuel injection system.
  9. SSchifko
    SSchifko New Member
    28
    Dec 11, 2015
    Western Wisconsin
    bourbon_scotch: With regards to your drawing, you got it right.
    The vent line can be used as a return line, but you need to run the vent line directly into the tank, not through the separator assembly.
  10. Queener
    Queener New Member
    Jun 6, 2016
    Lindsay, Ontario
    I am curious to know if you did end up using a vent for the fuel return with the sniper install? I am installing as well and I keep looking at those return lines wondering this same thing.
