Help me pick a roller cam
Discussion in 'Engine Topic' started by JWZ28, Nov 9, 2014.
  1. Rockhound
    Rockhound Veteran Member
    158
    Dec 3, 2007
    tennessee
    You'll loose a little compression with 64cc heads over the 305's 58cc. A decent set of 180cc or 195cc intake runner heads will really wake up your engine.
  2. earnhardtgm3
    earnhardtgm3 Veteran Member
    4,319
    52
    Dec 18, 2007
    Camaro Country,GA
    I ran that same cam in a 350 with AFR heads and ran like a bat out of h%ll, before I went to a stroker 388 motor. I'd spend the money on a good set of heads.
  3. Cataldo
    Cataldo Veteran Member Lifetime Gold Member
    2,649
    Jan 16, 2005
    San Bernardino, California, U.S.A.
    If your going to spend the money spend on quality. Afr heads are excellent heads any way you slice them. There are other companies that make excellent heads, but personally afr packs a whole lot into their heads. Top quality pieces. If aluminum is out of your pricerange vortecs are excellent options. Just understand their potential and limits.
  4. night rider
    night rider Veteran Member
    6,401
    Aug 6, 2002
    Bremen, Ga
    Vortec heads for budget heads
    Jegs heads
    Summit brand alum heads
    Pro filers
    Brodix IK 180 heads
    AFR
    Your headers will still work with vortec heads, temp sender is diff but you can get an adapter bushing or just move sender to intake.
    Vortecs are great heads but truth be told, I would not spend alot of money having a machine shop build you a set. The idea behind using them is budget. Get a used set cheap, have them tested for cracks, put good cheap springs on them, grind the retainers to work with higher cam lift, and have a good set of heads that can make 400 HP for 500 bucks
    If your spending more than that on them, there is better options with the aftermarket heads like I posted above.
  5. JWZ28
    JWZ28 Veteran Member
    1,239
    Feb 27, 2011
    Alabama
    Thanks for all the input. I'll have to pick my engine builder's brain on some numbers for a set of modified vortecs. May be able to swing some budget aluminum heads if Santa is generous this year.
  6. Cataldo
    2,649
    Jan 16, 2005
    Great advice there!
  7. JWZ28
    1,239
    Feb 27, 2011
    Alabama
  8. CorkyE
    11,513
    967
    Those seem to be a pretty good head, there are three 5 star reviews on Summit's site. If you search Blueprint, you'll find quality reviews scattered all over but they've seemed to have improved over the past couple years.
  9. JWZ28
    1,239
    Feb 27, 2011
    Alabama
    Ok so I know I'm going to go with a new set of heads, whether I have my builder do a vortec setup for me or go with a set of aluminum....
    As far as aluminum heads go, how much flow is too much on the intake side?
    I'm seeing heads anywhere from 170cc to 210cc. From what I understand, too much will kill the velocity depending on the motor. Is there a "golden" number I should look for? I hear 180-185cc intake is a solid number that won't kill the low end.
  10. Rockhound
    158
    Dec 3, 2007
    tennessee
    180cc heads would compliment your engine combo very nicely. A set of 195cc heads would flow better but might be a little large for your setup right now. If you plan on getting a bigger cam and upping your compression in the future, the 195's would work good.
