Help needed .How to mount deck
Discussion in 'Car Audio, Electronics & Security' started by 81z6.0, Mar 27, 2015.
  1. 81z6.0
    81z6.0 New Member
    27
    May 11, 2010
    central oregon
    Hi everyone
    How do I mount my single din pioneer stereo,I can not find a mounting kit.It must have been modded in the past because its just an opening not for a knob type .Thanks
  2. 81z6.0
    81z6.0 New Member
    27
    May 11, 2010
    central oregon
    paging mod Todd
  3. SupplySgt
    SupplySgt Veteran Member Lifetime Gold Member
    1,374
    Jun 20, 2009
    Finally back home!!!
    There is no mounting kit. If it's been modded, then it likely is the correct size. See if the stereo will fit in there. Mine is just slid into the hole and it hasn't moved since unless I pull it out.
  4. 81z6.0
    81z6.0 New Member
    27
    May 11, 2010
    central oregon
    It fits in the hole just need to figure out how everyone else that has a single din has them supported in the back and the front
  5. grzewnicki
    3,467
    188
    Dec 9, 2009
    Gordon from Jacksonville Fl
    I used one of the din sleeves, and in the back I mounted a metal bracket to the right hand dash support structure (the metal piece all the lower plastic pieces attach to) then mounted that bracket to the stud sticking out the back of the radio. post # 230 in my build thread shows the metal piece I made to fix my screwed up opening.
  6. hessdawg
    hessdawg Veteran Member
    316
    Feb 11, 2004
    marina , ca ,usa
    If it's been modded you should have a 7x2 inch hole cut in your dash
    The radio you have should have a cage to slide into that and a blackstrap to support the back of it
  7. 81z6.0
    81z6.0 New Member
    27
    May 11, 2010
    central oregon
    Thanks guys,will start install in next couple days
