Help Pitman arm AGR GEARBOX
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by BamaRocker, Mar 10, 2016.
  1. BamaRocker
    BamaRocker Veteran Member
    562
    Nov 29, 2005
    Meridianville, Alabama
    Few years back had someone install AGR GEARBOX in my 72 Camaro…Car react better but steering has been so sloppy, well I have a new guy looking at it now and apparently the pitman arm is way off…
    They original installed a straight pitman arm, I am needing one with and a bend or drop down to help with height difference.
    Does anyone know what pitman arm this would be….
    Thanks.
  2. Skip Fix
    Skip Fix Veteran Member
    2,217
    25
    Mar 21, 2007
    Katy,Texas
    Why do you need the drop one? My 79 PS Camaro had a straight 7", all Pontiacs have a shorter 6" dropped one. They just have to be matched to the correct centerlink at the idler arm side.
  3. grzewnicki
    3,579
    279
    Dec 9, 2009
    Gordon from Jacksonville Fl
    My 72 has a straight one in it, with an AGR box, no problems. I think my old manual steering box had a drop down arm, been a while so I don't really recall.
  4. BigBlock73
    2,182
    100
    Jul 10, 2002
    Accord,New York
    My 73 has a flat pitman arm and I swapped in a 89 IROC box and have no issues
  5. BamaRocker
    562
    Nov 29, 2005
    Well found out today why all the front suspension components do not line up, apparently the frame on my car is bent and off 2 or 3 inches. So now I am on the hunt for a new sub frame.
    Any suggestions on finding new one. Prefer stock.
